Tool Talk Discussion Forum
TSC oil
Jim in NC
05-28-2007 04:25:51
Who produces the "Traveller" brand oil for Tractor Supply? Anyone have any experience with it. Thanks for your response.
dhermesc
05-29-2007 14:12:39
 Re: TSC oil in reply to Jim in NC, 05-28-2007 04:25:51
I agree with Gene Davis post below. Check the API rating, after that the biggest differance is the amount of advertising they are charging you for.
James in North Carolina
05-28-2007 17:24:11
One of my in-laws works for the state dept. of agriculture and part of her job is testing oil. They do not test for the additives but they do test for SAE compliance. She told me that the only failures they've had were bulk oils from quick lube places and that was years ago. She said the stuff in bottles off the store shelf is almost always spot on.
TomTX
05-28-2007 16:05:36
Cheapest bid they can get; and when another bid gets cheaper, they will switch. Just my opinion, but I wouldn't run it in a red wagon. Tom
Jerry/MT
05-28-2007 10:23:44
These "private label" oils are made by the same folks who make all the other oils. If it meets the SAE weight and the API rating for your equipment then it's safe to use.
It's not like they have a special factory or make a special run to make a poor quality lubricant so they can sell it for cheap and ruin your equipment.The reason it's usually cheaper is because it's doen't benefit from the name brand's advertising dollars and the companies that sell it buy in large quantities.
Steve Crum
05-28-2007 04:52:31
I can't say with certainty, but it could be Ashland oil (makers of Valvoline) that produce this.
I use TSC Traveller lubes in everything but the Cadillacs and the truck engines, (Quaker State is easier to get while on the road). I've always had good results with Traveller lubes in the tractors, mowers, backhoes and other equipment.
Your results may vary.
VernMI
05-28-2007 08:56:29
 Re: TSC oil in reply to Steve Crum, 05-28-2007 04:52:31
Hello Steve
Aren't you the guy with the worn out cam gear on the 4.9 liter? I certainly don't know but maybe it was the quality of the oil you have been using. Could be a change in oil type may be in order.
Vern
Steve Crum
05-28-2007 09:52:07
 Re: TSC oil in reply to VernMI, 05-28-2007 08:56:29
Had you read the post, you would have seen that I don't use this oil in the truck or car engines. Secondly I bought this truck 4 months and 2,000 miles ago. So it's tough to say what oil was used in it. Could have even been the oil endorsed by you favorite NASCAR driver for all I know.
RayP(MI)
05-28-2007 04:45:11
Have used that brand in several machines, vehicles, with no problems.
Gene Davis (Ga.)
05-28-2007 18:19:01
 Re: TSC oil in reply to RayP(MI), 05-28-2007 04:45:11
Forget the front label with the brand name on the oil and look at the API specs, then the price if you are picky.
