Tool Talk Discussion Forum
tree stump burning
baler 46
05-27-2007 22:52:59
Hi
Just wondering if any one had any ideas on burning old tree stumps out? I have been pouring diesel fuel on top of them and letting it soak in for a long time, then i put charcoals on top of stump i put as many of the charcoals that will fit on top put some more fuel on the coals let sit a while athen light.Then we build a fire with wood logs on top of stump pretty big hopping it all burns up.Does any one have any good ideas? I have drilled big holes into the top of the stump and filled with salt and water to decay it faster to. thanks
dds-inc
05-29-2007 18:40:41
 Re: tree stump burning in reply to baler 46, 05-27-2007 22:52:59
I burn the same way. seems to take forever, doesnt it???? lol
sjh
05-28-2007 06:51:34
I have been told to put a barrel(open both ends)over the fire and it axes like a chimney. Just remember to block it up for ventilation on the bottom.
Midwest redneck
05-28-2007 05:07:24
I have an all wooded lot and I cut down a lot of trees. But so that I could have a little bit of a yard behind the house I just sawed the stump off flush with the ground and then filled over it will topsoil and planted grass. This works real good with the smaller trees (under 10" diameter) for the big ones with the large spreading roots it would be more work.
James Jackson
05-27-2007 23:50:29
Gooday baler 46 . Try drilling that big hole ( 12 to 14" deep X 3 or 4 " dia ( the bigger the better ) and fill up with whey as in Curds & Whey . Got 20 ltrs from our local dairy supplier for under $20 . Filled the hole 3 or 4 times & presto - it ate the tree stump away in time . Now I have a driveway 2x's wider & the pine trees aren't growing through my power lines . Don't forget to cover it up so it doesn't wash away or evaporate , though . Catch-y'all , James in Australia @ [email protected]
BigMarv1085 in Ga.
05-30-2007 22:45:14
 Re: tree stump burning in reply to James Jackson, 05-27-2007 23:50:29
I recently burn't out a white oak stump. Soaked it with oil for a couple of days, stacked limbs on top and started it on fire. Threw all of the old chunks of wood I could find and would let burn down, restarting it every afternoon. It was gone in about five afternoons.
