Tool Talk Discussion Forum
Installing an Oil Seal?
AWB
05-26-2007 17:29:06
How does one start an oil seal so as to get it installed correctly...without damaging it? Need special tools? Thanks.
Mike M
05-27-2007 12:12:08
 Re: Installing an Oil Seal? in reply to AWB, 05-26-2007 17:29:06
Another good method if you have a press is to press them in. Sockets work very well to push against. Just go slow so you can feel it go straight.
bo
05-26-2007 18:22:50
Just start to tap it in and then tap in a circle or....if not too big, use a socket of about the same size. You'll know when they get cocked and you can back off and correct. Tap....don't grab a BFH and beat it.
Pete in Cal
05-26-2007 18:09:50
Napa or other parts stores have seal drivers with a several diameters for different size seals. Its a lot easier to use than trying to start them by hand. Also less risk of ruining the seal when it gets cocked at an angle.
AWB
05-26-2007 18:22:55
 Re: Installing an Oil Seal? in reply to Pete in Cal, 05-26-2007 18:09:50
Pete in Cal: Thanks for the information relating to installing oil seals.
