Tool Talk Discussion Forum
Sanding belt splices
Bus Driver
05-26-2007 15:03:17
I use my 4 x 24 portable belt sander once in a while. Bought a quantity of new belts by mail order a few years ago. The splice is butted with a piece of tape on the back, advertised as "bumpless" splice. The splice is at an angle, as is typical. These belts do not have the skived lap splice that used to be the norm. But the splice tape is simply pulling loose now. Tape is sticky but has no holding power. How can I salvage these belts?
fzbcheve
05-27-2007 14:22:46
 Re: Sanding belt splices in reply to Bus Driver, 05-26-2007 15:03:17
had the same problem with the overlaped splice. used gorilla glue. works great.
Bus Driver
05-27-2007 14:32:50
 Re: Sanding belt splices in reply to fzbcheve, 05-27-2007 14:22:46
Obviously, the Gorilla glue was not used on the grit side of the belt. Did you glue the old tape back? New tape? Applied the Gorilla glue where and to what? If to the old tape, how did you align and hold the ends of the belt while the glue set? Sounds good. Please tell me the technique that worked for you.
Ken Combs
05-26-2007 15:35:23
I've had fair luck using the glass fibered shipping tape on these. Get a roll of the wide stuff, 1.5 or 2" and cut short pieces so that the fiber runs the length of the belt.
