Tool Talk Discussion Forum
Trailer brake adjustment?
Grub
05-23-2007 14:21:14
I"m checking out the electric trailer brakes before hay hauling time and I'm glad I did. This trailer is an auction special my wife bought and the outer bearings needed to be replaced and the brakes were pretty rusty.
Two questions- what is the correct way to adjust the tension on the shoes? Do I spin the drum til it drags or stops and then back off the star wheel a certain number of clicks?
Second question on bearing tension (inner and outer tapered roller bearings) how tight do I torque the nut and then how far to back off?
Thanks muchly!
Grub
BF8690
05-24-2007 12:50:05
 Re: Trailer brake adjustment? in reply to Grub, 05-23-2007 14:21:14
On the bearings, usually they get torqued to 50 f t lbs and back off a quarter turn. Spin the wheel while doing that. The 50 ft lbs puts the pre-load on the bearing. Backing it off the quarter turn sets the torque back to zero.
Larry in Mo
05-23-2007 15:52:19
Grub; On brakes this is what I used when 18 wheeling. Tighten shoes down fairly solid, then start backing off and tap the brake drum with the wrench that you use. The drum should ring like a bell when the shoes are clear and properly adjusted. If you get a "doink" you need to back off some more. On wheel bearings, tighten the nut till you can feel a good drag on the wheel, then back off to the next castellation and check again. That should put you right on the money. LE
BF8690
05-24-2007 12:51:22
 Re: Trailer brake adjustment? in reply to Larry in Mo, 05-23-2007 15:52:19
That is exactly how I was taught to do drum brakes. My grandad taught me that. I do bearings differently as I stated above.
