Tool Talk Discussion Forum
Surge brakes on trailer
rossow (mn)
05-23-2007 11:31:40
Can I use a regular trailer surge-brake actuator on a homemade brake setup -- that is, one made up of salvage-yard parts (hubs, drums, shoes, etc.)? It seems I could build my own axles and add the salvage hubs, backing plates, etc., a LOT cheaper than buying all new. Any reason it wouldn't work as long as the parts are all in good condition? (In other words, does the actuator care what's on the other end?)
mjbrown
05-24-2007 08:23:22
 Re: Surge brakes on trailer in reply to rossow (mn), 05-23-2007 11:31:40
Yes, If you know what you are doing (some one's life will depend on it) and your labor is worth nothing because it will take a lot. If you are knowledgeable enough to put together a good brake system this way, why is your time so worthless?
rossow (mn)
05-25-2007 08:49:22
 Re: Surge brakes on trailer in reply to mjbrown, 05-24-2007 08:23:22
I'd rather spend my time working on projects like this than sitting around watching TV. It's a way to unwind. It's not work, it's fun. And, yes, I feel competent to do the brake system once I collect the right parts. Along with working on drum-brake systems in my own and others' cars and trucks since the mid 1960s, I've had more than 600 hours of tech-school training in auto-related stuff.
RustyFarmall
05-23-2007 12:47:45
Ever pulled a trailer with those surge brakes? Bumpy roads will give you fits, and just wait until you try to back up! Besides, I don't think they are approved for highway use.
Bf8690
05-24-2007 12:54:32
 Re: Surge brakes on trailer in reply to RustyFarmall, 05-23-2007 12:47:45
I hate surge brakes. Some trailers you have to get out of your truck and pin the actuator so you can back the trailer up. That can be a major pain the ____.
Bf8690
05-24-2007 12:53:22
nballen
05-23-2007 15:19:16
U-Haul trailers are set up with surge brakes. They can't really require (or supply) an electronic controller with every trailer rental.
Nathaniel
oldrustycars
05-23-2007 11:34:54
"probably". as long as the wheel cylinder capacity isnt more than the master cylinder capacity. Still, new Dexter stuff isnt that expensive, plus you can get "free backing" brakes that dont lock up when you back up.
