Tool Talk Discussion Forum
OT JD Kawasaki motor question
Christian_CT
05-19-2007 17:36:59
Have a Kawasaki FB460V 12.5hp gas engine on a JD 52" walk behind mower.
Not starting. Its blowing a flame out the carb. Is this a sign of a stuck valve? No noticable compression when placing finger over spark plug hole (plug pulled --pull starting engine).
Any thoughts? Pull the head off and see whats going on? Really don't want to spend to much $$ on this engine willing to pull head and wire brush off carbon to free valves after that? What else could it be (have not hit anything --timing should be on).
Thanks for any help
cat236
05-20-2007 20:20:49
 Re: OT JD Kawasaki motor question in reply to Christian_CT, 05-19-2007 17:36:59
I would say the most common problem when valves start to sticking is old stale fuel being run through machine,the "varnish" deposits stick to valve stem, with only a few thousandths in clearance it dont take much to get them to sticking. I would also check your spark plug as it can cause this problem as well, I have seen many of this series Kaw's act up and simply be a plug.Also check your igniter located on right side of engine near dipstick tube, this controls spark and can also cause your complaint, good luck to you
Odie1
05-19-2007 18:20:12
Chris,
Just had the same trouble on mine, for the second time in about 4 years.
It seems that the intake valve - or seat - tends to wear not letting the valve close. I had to pull the valve and take off a few thousanths off the stem so it would close. Does require you to get a valve spring tool, but not too difficult a job. Of course the head has to come off to get the valve out....
I think the clearence is suppose to be .006
Good luck!
Odie1
christian_ct
05-22-2007 06:16:34
 Re: OT JD Kawasaki motor question in reply to Odie1, 05-19-2007 18:20:12
Stuck exhaust valve was the culprit. Cleaned the head and valves re-assembled ran pretty good. Once I get a valve/spring compressor I'll do a complete valve job.
Thanks.
