Tool Talk Discussion Forum
Maybe OT---Grass ONLY Killer
Jiles
05-13-2007 18:19:34
Does anyone know of a herbacide that will kill ONLY grass? I have a special situation with my landscaping that requires me to kill the grass around thrift and other type shubbery. I know that most people use a ground cover overlaid with rocks or chips but this is an existing bed on a hillside.
Greg NAA
05-14-2007 15:36:57
 Re: Maybe OT---Grass ONLY Killer in reply to Jiles, 05-13-2007 18:19:34
I've used Poast (sethoxydim) to kill grass around my tree farm. As another said, Fulisade is an option too.
Greg
kyplowboy
05-14-2007 20:00:25
 Re: Maybe OT---Grass ONLY Killer in reply to Greg NAA, 05-14-2007 15:36:57
poast is the only "grass only" labeled for tobacco that I know of. I use it on tobacco and my grandmother's flower beds. Good stuff, high doller but a little goes a long way.
Jiles
05-14-2007 06:45:16
AMAZING how much knowledge is available from people on this web site. I knew there had to be an answer to this problem. I have not found this type information anywhere. THANKS for the responses!
L.C. Gray
05-13-2007 20:02:52
"Over the Top" available from a good nursery is a selective herbicide for grasses and can be used on your flowerbeds with bedding plants, ornamentals, trees and shrubs or on your garden with vegetables. Just keep in mind... there could be plants in either that may be members of the grass family, such as Monkey Grass, Lirope, Pampas Grass, Corn even Palmtrees so make sure of what you have in there won't be affected as well as the grass you're tyring to kill.
Another more widely used agricultural selective for grasses is Poast.
Tim B from MA
05-14-2007 08:14:14
 Re: Maybe OT---Grass ONLY Killer in reply to L.C. Gray, 05-13-2007 20:02:52
I am guessing but those herbicides are probably selective for killing monocots (grass, corn, palms) vs. dicots (most flowering plants, trees, shurbs)
You can tell the difference from the leaves. Monocot leaf veins are parrallel to eachother and the axis of the leaf or leaflets. Dicot leaves have branched veins.
rgvtx
05-13-2007 18:51:34
In similar situations, I use Roundup in a 3 gallon pump up sprayer and use a long handle metal paint shield to protect the favorable plants. Been doing this for a number of years in the veggie garden and also around plantings around the house that I'm too lazy to weedeat around. The shield I refer to had a wooden handle a few feet long. The shield is aluminum and about 1 foot by 3 feet and has a wing nut and bolt so the angle can be adjusted. Obviously you need both hands to do this so I put a strap on my sprayer to carry it on my shoulder. I have seen people use a piece of cardboard for the same effect but if the cardboard gets too wet and the chemical soaks through then you are rubbing the wet side of the cardboard on your favorable plants. Below is a link to one very similar to the one I use. Mine came from Home Depot quite a few years ago. I used it once and stored it and then discovered a new use for it.
Texas Sand
05-13-2007 18:48:42
There are 2 products the I use on my cotton farm, Select or Fusilade. If you are unable to find them let me know, they are readily available here.
