Tool Talk Discussion Forum
hydrolic chainsaw
ww
05-11-2007 09:49:28
where can I find info to buy one?
Pete in MD
05-14-2007 20:01:37
 Re: hydraulic chainsaw in reply to ww, 05-11-2007 09:49:28
ww,
I've got one I'll sell. I sent you an email.
Pete
Gus
05-13-2007 03:56:21
 Re: hydrolic chainsaw in reply to ww, 05-11-2007 09:49:28
You got me curious now. Are you going to run it off a tractors hydraulics? Seems like it would be kind of clumsy in the woods. Or are you working on a pile?I would be the first one to saw the hydraulic line in two.
ww
05-13-2007 04:02:59
 Re: hydrolic chainsaw in reply to Gus, 05-13-2007 03:56:21
I'm making a firewood processor
Jon Hagen
05-14-2007 20:46:10
 Re: hydrolic chainsaw in reply to ww, 05-13-2007 04:02:59
Got one that has hung in the rafters of my pole barn, new and never used for 25 years. I took it in as payment for car repair from a guy selling them . It is a big two man affair with a handle at both ends of it's 4 ft citter bar. It has a pto hyd pump with oil tank and 1/2 inch hyd hoses connecting it to the hyd motor in the saw handle
It has a little needle valve that bleeds off a bit of hyd oil to oil the chain and bar. I have not a clue what brand ? Its painted green.
Gus
05-13-2007 04:23:27
OK, never thought of that. I've only seen one years ago. Would like to see some pictures of it sometime.
MSM
05-12-2007 16:25:28
There is one on ebay now,ends in 16 hours,($250)
Gerald J.
05-12-2007 09:01:37
Be sure to be seated when you are about to receive the answer to the question, "how much?". These are generally heavy duty commercial industrial saws with significant prices, several times what you'd pay for a gas or electric chain saw at a hardware store or home center.
Gerald J.
railhead
05-11-2007 19:31:07
I work for the the railroad and as Stanley makes many of our hyd track tools, they also make a hyd chainsaw. I have no idea where you would go to buy one however. Maybe look at Stanley online and see if they have a link to hyd tools (and track tools???) Best of luck.
ww
05-12-2007 03:31:12
 Re: hydrolic chainsaw in reply to railhead, 05-11-2007 19:31:07
thanks to everyone, now I nave places to start looking.
Charles (in GA)
05-11-2007 14:50:47
Most of your tree trimmer bucket trucks use them, but are powered off the hydraulics of the truck/bucket system. As far as a stand alone unit, it would take a pretty decent sized small engine driven power pack to run one.
Charles
Angle Iron
05-11-2007 14:42:47
Might check with local power co or tree service that cuts trees around power lines with basket truck. They use this type of saw around here, coastal SC. angle Iron
Angle Iron
05-11-2007 14:41:12
glennster
05-11-2007 11:03:56
here is a company that sells them
www.bcaequip.com/saws.htm, predominately for underwater work
J Plunkett
05-11-2007 10:23:30
I worked in 2 underground coal mines at the second mine we had them might try mine supply on line. Maybe can find out who still makes them and go from there
Ken Macfarlane
05-11-2007 10:20:30
What type? I know northern tools sells one with diamond chain for contrete cutting. I've seen other for underwater tree cutting too. I've seen fire figher models for cutting cars and roofs open with carbide tipped chains.
