Tool Talk Discussion Forum
Hydraulic Control Valves
Richard Fazio
05-10-2007 08:54:18
I'm looking to buy some new hydraulic control valves for my backhoe. The old ones are shot and new ones are cheaper than having the old ones rebuilt. I need some help with the terminology of the valves. They talk about 3-way 3-position or 4-way 3-position etc. I think I need 4-way 3-position spring centered. The backhoe has all double action cylinders. All cylinders I want to stay where they are left. I want no float on any cylinder I do want to be able to move two cylinders at once. These valves are 4 for the backhoe arm and 2 for the feet on each side of the unit. Thanks in advance for any help.
Richard Fazio
05-11-2007 08:04:55
 Re: Hydraulic Control Valves in reply to Richard Fazio, 05-10-2007 08:54:18
Thanks for the info guys. Now I have to determine what type of system I have.
135 Fan
05-10-2007 21:53:58
4 way means double acting. You also want valves that can operate at the same time. Not all of them do and make sure to get the right type of valves for open or closed center. Whatever your backhoe is. Lastly you need to know how much hydraulic flow you have so you can size your valves accordingly. Dave
big jt
05-10-2007 09:09:04
Here is a link to a simple explaination of the valves. This place will probably have what you need also.
jt
