Tool Talk Discussion Forum
Top dead center, compression
Slowpoke
05-10-2007 01:44:09
I had to replace the harmonic balancer on a recently aquired F250, 460 engine because the original balancer came apart and the timing marks moved about 120�. Of course I pulled the distributor out before I found out why the marks moved....and now I can't get the engine started no matter what. How can I set #1 to top dead center on the compression stroke without removing the valve cover to see that both valves are closed?
Thanks
Mark In Monroe
05-10-2007 02:33:08
 Re: Top dead center, compression in reply to Slowpoke, 05-10-2007 01:44:09
Hey Slowpoke, Take out #1 Spark plug and put your finger over the plug hole and crank the engine over slowly. When the pressure pushes your finger off the plug hole, you coming up on TDC. Now look at the timing marks on the dampner and line up the "0" Degree mark with the pointer. That will give you a place to start. Then put in the distributor with the rotor pointing #1 plug wire on the Dist.Cap. Make sure the Dist. seats all the way down to the block, to be sure the oil pump drive shaft is engaged to the bottom of the dist. drive shaft. Put a timing light on spark plug #1 and set the timing to the factory specs.
Good Luck- Mark
Slowpoke
05-12-2007 01:07:50
 Re: Top dead center, compression in reply to Mark In Monroe, 05-10-2007 02:33:08
Mark, that finger in the hole is easier said than done. The hole is recessed and it would take another person to turn the crank with a long handled ratchet.
But I did manage to find compression TDC by using a screw-in compression tester. Ten psi was the max as I slowly turned the crank. It dropped back to zero each time I backed up the ratchet, but there was no question as to compression TDC when I did two revs of the crank and came up on zero�. The engine fired instantly with starter fluid. Now there's no fuel to the carb! What's next???
Allan In NE
05-10-2007 04:44:24
Just for what it's worth,
If you connect the timing light on the coil wire instead of the the #1 wire, it works sooooo much better.
Just thought I'd pass it on.
Allan
Bill-KCKs
05-10-2007 09:38:49
 Re: Top dead center, compression in reply to Allan In NE, 05-10-2007 04:44:24
Rather than using your finger, put a cork stopper in the sparkplug hole. When you get to the top of the compression stroke, the cork will "pop."
You may never find it.....
