Tool Talk Discussion Forum
Wet Sandblaster Media
mike6845
05-07-2007 18:00:46
I finally got my Northern wet sandblaster going today and determined real quick that this thing is going to suck a lot of sand through it for what I have planned to do. My question to you guys is what media are you using and how are you drying it before you use it as I am assuming that some of you use play sand or equivalent. also, any suggestions as to what media to get from Menards? Does anyone recycle their wet sand after drying also?
mjbrown
05-08-2007 05:18:29
 Re: Wet Sandblaster Media in reply to mike6845, 05-07-2007 18:00:46
I have the same one you have and I had problems with play sand. It cakes up too easily and plugs the tube. I have had my best results with Black Beauty whick is a slag product. It's not cheap but it flows well and is sharp so it peels off paint and rust in a hurry. I drop the bag in a trash can and poke the pick up probe throught the paper. I use it in a gravel parking lot and make no attempt to reclaim it. I don't think it hurts anything. You will want to cover up especially your eyes.
IH2444
05-08-2007 14:54:00
 Re: Wet Sandblaster Media in reply to mjbrown, 05-08-2007 05:18:29
I use the black beauty for dry blasting, good stuff.
about $9 for a 90 lb bag. I have a sealed blasting stall where I vacuum up mine and screen it and use it again.
jeffcat
05-08-2007 00:53:58
Not to brag but I live in South Jersey where it is a giant cat box. I just drive my little John Deere 180 and the cart over to the side of the railroad cut. July and August the sand is bone dry for a good six inches and I just scoop it off of the top. Sift it through the biggest flower sifter you can buy into a 30 gallon trash can. I have two cans full of bone dry sand. Be careful with play sand cause I bought some that had lime mud in it. That is ground up sea shells to you all. What a mess! Black agge is the best but not cheep. Recycle will usually only do ya one time and then you have dust. NEVER put your hand in front of a water blaster! You will be messed up cause it will inject the sand into you! Not like an air blaster that will just sting ya. My two pennys worth, Jeffcat
Sand
05-07-2007 20:42:53
The sand that I buy at Menards is either the silica sand, about 3 bucks per 50 pound bag or the sand that is black in color. I cant remember what it is called but it is about 6 bucks a bag. I think that it works a lot better on cast iron than the silica does.
