Tool Talk Discussion Forum
DPST switch
woodbutcher
05-04-2007 09:13:13
This is a followup question concerning my bench grinder switch. The original switch has a T-handle that was in the off position when pushed in and on when pulled out. But when I looked inside, it appears that pulling the handle out pulls the copper bars away from the contacts the wires are attached to. If I wire in a regular single pole switch, the wires that the bar is pulling away from now will never be separated, and the grinder will never turn. Am I missing something about the way the old switch worked?
Butch
jeffcat
05-05-2007 09:23:42
 Re: DPST switch in reply to woodbutcher, 05-04-2007 09:13:13
Another little note. If it is 120vac grinder the only reason it has DPDT swith is to break both sides of the line. Thus you have a double shealded motor. If you see anything that looks a little funny buy a new switch. Motor repair places would be the best bet. jeffcat
woodbutcher
05-04-2007 13:01:51
Thanks to all. When the switch came apart, I didn't notice the two springs that cause the plate and contact bars to move opposite the direction of the T-handle. I think I may be able to put it back together and make it work. If not, I'll google DPST.
Butch
Vern-MI
05-05-2007 08:23:47
 Re: DPST switch in reply to woodbutcher, 05-04-2007 13:01:51
If you can't fix it try Grizzly tools. They have them for about $3.50 with a paddle and a safety key.
Glen in TX
05-04-2007 12:55:37
Try a local electric motor rebuilding shop or a Grainger dealer or other electrical supply houses.
CENTAUR
05-04-2007 12:46:41
Go to GOGGLE and enter(DPST switch) and the 2nd down on the first page has excellant pics& diagrams. CENTAUR
Turtle
05-04-2007 09:38:15
The switch is a double pole single throw (DPST). That means it has two sets of contacts to work with. I would be careful to put a switch back on the unit that works in the same way as the one installed for safety reasons. Pull on push off style, it is done that way as a standard so in case of an accident it can readily be pushed off. If using a single pole single throw (SPST) you will have to make sure it is set up in this way of contacts closing in the pulled position. Hope this helps.
woodbutcher
05-04-2007 10:22:35
 Re: DPST switch in reply to Turtle, 05-04-2007 09:38:15
Thanks, Turtle. I'm in favor of safety, but I can't find a replacement that works like the original.
Butch
Jim K
05-04-2007 18:26:12
 Re: DPST switch in reply to woodbutcher, 05-04-2007 10:22:35
I have alot of luck with old switches especially the good old ones that you can take apart, usually just clean the contacts put it back together and good to go.
