Tool Talk Discussion Forum
Sandblaster
lucasd
05-02-2007 14:47:56
I am looking to buy a portable sandblaster. I would like to know what some of you guys have used and liked. There a bunch out there and I don't want to buy junk.
Thanks,
Lucas
old
05-02-2007 20:00:42
 Re: Sandblaster in reply to lucasd, 05-02-2007 14:47:56
For small stuff I like my $12 wal mart siphone sand balster. Its cheap but works well for the small stuff. For the bigger stuff I use a pressure tank type I got from habor frieght works well after I modified it. The shut off valve on the bottom of the tank would clog up so I said to heck with it and took it off now it works real good and cost around $70 for it
jeffcat
05-02-2007 18:16:35
Real quick. You want a pressure pot type of blaster. I use a small tip so that my compresser can keep up. If you can get a compresser big enough to run a 90lb. jack hammer, then you have just enough air. WATCH your lungs cause the dust will do you in. jeffcat
Stan in Oly, WA
05-02-2007 17:23:01
Hi Lucas,
On the home page of this site, directly under the red banner which reads Tool Talk Discussion Board is a link called View Archives. There have been hundreds, if not thousands, of postings on the subject of sandblasters, and all of them are available in the archives.
The two main things I have learned about sandblasters on this site is that they require more air than just about any other air tool so you'll be disappointed unless you have a bigger compressor than you can afford, and second, compressor capacity rating information is always overstated by the manufacturer (or retailer), while sandblaster air requirement information is frequently understated. I believe the technical term for this situation is "double whammy".
All the best, Stan
mjbrown
05-02-2007 16:32:13
I use a wet blast attachment for my power washer. I got it from Northern Tool. It works much faster than an air sand blaster and the water knocks down the dust and paint etc. It's for doing big stuff like trailers that the water stream won't blow away. For smallish stuff air might be better.
