As the others said.. it's not cut / dry. here are a few choices for ya. 1 Run it wide open.. but on a thermostat setup like a small heater ( 1500w is common for those thermostats ). 2 Perhaps a wire feed motor speed trim variable resistor from a mig welder would do. they are a low ohm value, ceramic potted and look heavy duty... not sure how much cut you would get without looking at the actual resistance/impediance of whatever you use. 3 Get a multi position rotary switch and solder in a few fixxed hi-wattage ceramic power resistors.. say 3 of tem to make a hi / med / low. Up you you to use E=IR ( P=IE ) to decide what values of R you want for the hi / med / low... etc. 4 The variac xformer is a great idea. If you can find one cheaply you will be very lucky... 5 A lamp dimmer module meant for stage lighting. ( par can controller ).. you should be ably to find one in the 1500w range easilly.. as you can find lamps up to 1kw in many venues ). 6 Build a triac based controller ( lamp dimmer ) using off the shelf parts.. but rated for the load. 7 Build a Pulse width modulator and feed with full wave filtered DC. 1500w can be handled with a handfull of off the shelf mosfets.. irf 511 or irf z40, paralleled will do the trick... ( pwm is not my first choice since you are working with ac source... ) ( now don't you wish you had taken HS electronics!! ) Good luck!! Soundguy
