Tool Talk Discussion Forum
Fordson dexta hydraulic service
ron ohler
04-30-2007 19:37:57
I'm rebuilding the hydraulic system on my Dexta. Hopefully starting to reassembe it tomorrow. I've had to reman the linkages and draft control shaft as they were very worn. My question is that one control arm(#957E-680) has a dowel pin that rides a cam on the rocker arm. It has 2 flats on it. One where it rides on the cam and another that I believe might be for clearance. I'm trying to find out if the pin has worn from riding on the rocker arm cam or if it was ground this way at the factory. Another question is where the lift arm setting gauge(N-503)actually holds the arm in relation to the gasket surface. I've got a full service shop and would rather make the right gauges than do the fudges that are in my manual. Oh, is there any way to check the shape of the draft control link(957E-540)without comparing it to a new one as outlined in my manual?
Thanks, Ron
