Tool Talk Discussion Forum
What will the pump cost?
jCarroll
04-29-2007 19:24:33
Assume I will have a 350' well, with flow no more than 3 gpm, in a 4" PVC casing.
What will I expect to pay just for the pump & pipe in the well - ignore the cost of trenching from the well head to the house, wiring & pipe in the trench.
jdemaris
04-30-2007 12:27:59
 Re: What will the pump cost? in reply to jCarroll, 04-29-2007 19:24:33
I know of at least a dozen companies selling 4" pumps - but they are becoming "specialty items" and tend to cost more then the more conventional larger pumps. Grundflo, Shurflo,Sun, Lorentz, etc. have some in the $600 price range and up.
With new wells, the 4" casings are often used for solar-electric hookup with a low-yield well. Whenever the sun shines, the pump turns on and pumps water into a tank or cistern. The tank than gravity feeds to the place of demand.
With a conventional 6" well, I can buy a new 1/2 horse pump for $450. With a 300' well, you'd also need 300' of wire, waterproof connectors, heavy-grade plastic pipe (160 PSI), anti-torque ring, saftey-rope, and a brass pitless-adapter to install into the well casing.
T_Bone
04-30-2007 10:18:32
Hi JCarroll,
I just drilled a new 6" well to 340ft and am going to drop in a 1hp Flint Walling SS pump & Franklin motor at $585 that'll pump 12gpm at 295ft.
At 3gpm you would be in the 1/2hp pumps?, about $500 at the same place I bought from. The big jump in cost comes in at 1-1/2hp pumps that start in the $700 range then jump to $1200 depending on the gpm wanted. 14gpm to 25gpm
Well casing PVC is 4.375" ID and 5"OD at the couplers. All the SS pumps/motors I spec'd were 3.875"OD upto 30gpm.
The steel casing was another $6ft over the PVC cased price but is was only 5" thin wall, or sch10 pipe. I just didn't think it was worth the extra $6ft.
T_Bone
VaTom
04-30-2007 05:31:23
As others asked, are you sure it's a 4" casing? 6" is standard here. Mine, however, is 4".
A standard pump is 3 7/8" diameter. Which in all probability will not go down your 4" bore after your casing stops, assuming it does. Here, we drill to bedrock and the casing stops there. The bore continues to water and get a reservoir.
Far as I know there's only 1 manufacturer of a smaller diameter pump, Grundfos. They discontinued everything but stainless pumps a few years ago. I got an opportunity to buy a pair of stainless pumps for $350 ea and jumped. Normally at least twice that. Excellent pumps. Pipe's cheap.
Pumps are sized for head and gpm. Head doesn't necessarily stop with the top of the casing, depends on where your house is. My house is 150' higher than my well-head. Give the Grundfos folks your volume and head and they'll get you the correct pump. I was sold the wrong pump by a local drillers' supply house twice. Wouldn't take them back even though it was their error. 2 minutes on the phone with Grundfos and I knew what I needed. They also told me where else I could buy their pumps.
jCarroll
04-30-2007 04:53:45
The drilled hole is 6 5/8". with a 6" steel casing through sand and gravel. No casing through clay. After drilling is complete, the hole is lined with 4" perforated PVC.
Well is in South central Colorado.
VaTom
04-30-2007 05:39:18
 Re: What will the pump cost? in reply to jCarroll, 04-30-2007 04:53:45
Oops, coffee just kicked in. Didn't notice you were the OP.
You'll be able to get anybody's 3 7/8" pump down your casing. Unless you've got a drillers' supply nearby, you'd do well to internet search for best price. Unless your water is really bad, you don't need stainless. My non-stainless Grundfos has been in my well for almost 20 yrs. The others are sitting on the shelf as backup. Probably next Labor Day or New Years'Day or... You get the drift.
oldfarmtractor
04-29-2007 20:40:11
Why only a 4" casing and thus a 4" well shaft? A 6" casing is over twice the size of a 4" and will hold that much more water.
Steve Crum
04-29-2007 20:36:40
A 4" PVC casing is a new one on me. Everything around here is 6" steel at least and driven to bedrock. Helped the neighbor put in a new 3/4 horse pump and piping last fall. I think he said the 70' of pipe, wire, 3 torque arresters and new clear well pitless adapter were around $775.00.
I did the hoe work for a 12 pack of Molson's.
Lincoln
04-29-2007 19:55:58
I just replaced the pump im my well. I bought a 1hp pump for $857.00. Mine is down 258 feet. I reused the pipe so I can't help you out there.
Coloken
04-29-2007 19:49:55
Be carefull about putting a pump in a 4 inch caseing. Used to be 4 inch pumps go in a 4 inch caseing, but after a few years rust and such make it hard to pull out. PVC may be OK. Just wanted to call your attension to it.
