Tool Talk Discussion Forum
auto idle
Little Ed
04-29-2007 06:38:16
I am thinking about getting a welder unit from Surplus Center and hooking it up to an engine from a 93 International combine. Does anyone Know how I could rig up an auto-idle system?
dave guest
05-01-2007 18:36:43
 Re: auto idle in reply to Little Ed, 04-29-2007 06:38:16
How about choke cable and a little imagination?
NC Wayne
04-29-2007 18:56:39
Unless your planning to burn a rod or two and rest a few minutes, then burn a few more and rest a few more, etc etc I wouldn't worry about it. If you stop welding long enough for idling the engine down to make a discernable difference in fuel consumption you can do it manually and save the extra parts and expense for a nice new helment, gloves, etc. I say this mainly because I've never owned a welder that had an idle control board that lasted more than maybe 6 months. When it was working it would always seem to idle down at the worst time, like just as I got ready to start an arc while standing on my head welding down in a hole while using a mirror....Ok, maybe that's a little bit of an extreem situation, though I have done it once or twice. Point is, to me, auto idle has always been a problimatic feature, at best, and one that there's really not a need for unless you were welding say 500 feet from the machine for hours on end and often had to stop welding to perform another task. In that case it's not feasible to walk back to the machine every time but if your not far from it why not..... Just my .02 for what it's worth....
jmixigo
04-29-2007 06:48:08
Find a factory welder with an engine as much like yours as possible. One that has the throttle on the same side of the engine as your engine. If you're slick enough to build a welder, once ya see how the idler works it'll be no problem to rig up. I've replaced a few on factory welders an they're pretty simple.
135 Fan
04-29-2007 08:42:49
 Re: auto idle in reply to jmixigo, 04-29-2007 06:48:08
Some of them work off of vacuum but I'm not sure what causes them to speed up the engine. Dave
jmixigo
04-29-2007 10:29:58
 Re: auto idle in reply to 135 Fan, 04-29-2007 08:42:49
Many of the newer units an most diesels are electric (electronic?) an actuate a solinoid that just pulls the throttle up to operating speed. There is a delay unit incorporated into it (some times adjustable) that controlls how quick it returns to low idle. I don't understand all the theory involved nor could I build ya one, but installing the thing is pretty straight forward.
Little Ed
04-30-2007 19:40:44
 Re: auto idle in reply to jmixigo, 04-29-2007 10:29:58
Thanks for the input, guys. I always get great ideas from this site.
