Tool Talk Discussion Forum
New to forum, question w/o war, weld ss to steel
Farmall MD nut
04-26-2007 15:20:34
Hi Guys. I'm pretty new to this and I must say I'm kinda iffy about asking a question with some of these word wars going on. It's not just here, it's in the tractors too. Over there some poor guy is having trouble with getting his H running, and everyone is laughing at him and making fun of him.
When I first heard of this site I thought it be great. But it's a shame how some of these people reply to questions. You can only learn If you ask. We all have to start somewhere, we're not born with college degrees.
Anyway, I don't want to start anything, but what is the best rod for welding stainless to steel? I've always heard people say 309 is best for dissimalar. I've got a 1 3/8" round bar that I want to add 5" of stainless on the end of it. I'd like to use stainless because it will be female threaded and in harsh conditions and I don't want the threads to rust. Thanks, Farmall MD nut
T_Bone
04-28-2007 13:09:21
 Re: New to forum, question w/o war, weld ss to ste in reply to Farmall MD nut, 04-26-2007 15:20:34
Hi FMDnut,
You didn't give use alot to go on as to the type of SS and the weld process your using. That being then I would use E307 as it adds a touch of Mo to cover a wider range of compatibility, mostly to stop weld cracking.
7018 would be a poor choice as your need to add Cr & Ni back into the weld that is lost during the welding process.
I would also suggest you butter weld the mild steel face then fit the joint together then weld with E307 or E309.
T_Bone
Farmall MD nut
04-28-2007 13:53:31
 Re: New to forum, question w/o war, weld ss to ste in reply to T_Bone, 04-28-2007 13:09:21
Hi T bone. Yeah I really didn"t give alot did I. The steel is just plain hot rolled and the stainless is you"re most common 308. I was planning on stick welding it today, but didn"t get to it. I was also toying with the idea of flux coring it. We have some 1/16" 308 flux core that needs gas. We always use the tri mix, cause I beleive that helium is needed for that extra heat boost.
You mentioned "a touch of Mo". Are you refering to Molybdenem?(I"m not sure i spelled it right) If I remember right the chromium and nickle are in most of the stainless rods correct? You said butter weld. Is that welding a hot stalled puddle on the end of the steel?
T_Bone
04-28-2007 23:23:08
 Re: New to forum, question w/o war, weld ss to ste in reply to Farmall MD nut, 04-28-2007 13:53:31
Hi FMDnut,
Mo= molybdenum
To butter base metal means to add a independnt layer of filler rod before the main weld is completed. Look at this preweld as a transistion to the base metal to the adjoining piece to be added. This will stop alot of weld cracking and/or weld tear out under severe use.
So in your joint we would butter the mild steel rod face with E307/E309 as then when the final weldment is made you would be joining two grades of SS and not one mild steel and one SS. You might consider using SMAW using E307/E309.
Butter welding also is common on dirt buckets before hardface rod is put on. This would keep base metal shock lower while using the bucket in rocky soil.
E308 will probably fail at some point well before maximum design stress as it doesn't have the additional Cr & Ni that's needed. You should also use Ar-95/O2-5 or Ar-97/o2-3 for a shielding gas for your joint design. With o2 added too the Ar would achive deep penetration. You should also consider using a post pruge cup on the bottom of the weld zone to keep porosity out of the weldment.
The addition of HE would not react well with the mild steel. The HE would cause the carbon to pool in the weld puddle and make it brittle.
T_Bone
Farmall MD nut
04-30-2007 14:56:05
 Re: New to forum, question w/o war, weld ss to ste in reply to T_Bone, 04-28-2007 23:23:08
Hi T bone. Yeah, gotcha. That makes alot of sense adding a layer of weld bead. I'd have never guessed that helium doesn't react well with steel. I've run out of AG 25 while 1/16 flux coring already and used the tri mix to finish the day out. Didn't have any problems. Everything still in tact. But, Tri mix is fine with welding ss to ss correct?
Farmall MD nut
04-27-2007 16:58:21
Wow, looks like it happened anyway. Well thanks guys, we got 309 at the shop, I"m gonna give it a whirl tommorrow. Thanks again.
NEsota
04-27-2007 06:28:35
That little spat added interest to the forum. The information coming with it will be remembered long after it is forgotten.
Taterchucker
04-27-2007 14:01:16
 Re: New to forum, question w/o war, weld ss to ste in reply to NEsota, 04-27-2007 06:28:35
Just curious, How can it be remembered if it is forgotten?
Oliver Power
04-27-2007 03:39:34
An industrial boiler factory would use rod or wire called "inconel". But , that"s a boiler factory. Ex-rayed joints , high preasure , etc.. They would weld together what they called hubs. A short 3 inch piece of stainless , and a 3 inch piece of carbon would be welded together in the factory useing inconel filler. The hubs would then be welded on to the end of a coil , which made it easyer for welders to fabricate out on the job site. For the average Joe , use what you want.
DNWELDMAN
04-27-2007 01:32:37
Hi Farmall nut. Yeah, I"d run with the 309. Runing stainless stick is a bit different than a 7018. If you can, grab some drops and practice a little. Still use same method, drag the rod. You said round bar, bevel both peices, then tack em together. Have a buddy turn it for you on the bench while your welding it. Make sure he"s not looking at it. It"ll turn out pretty sweet that way. Doug
jeffcat
04-26-2007 21:21:08
Just a little of the path. Did any of you guys see "How It's Made" a couple of weeks ago? They showed how welding rod is made. WOW it was neat to see how much goes into that pile of metal rods next to your welder! The flux is there more to keep Oxygen and thus Co2 away from the molten metal more than anything. You wouldn't think it could cause so many brittle and temper problems! They found out during WWII with those cargo ships! Jeffcat
135 Fan
04-26-2007 21:34:55
 Re: New to forum, question w/o war, weld ss to ste in reply to jeffcat, 04-26-2007 21:21:08
I didn't see it. Too bad. I know the recipe for the flux's is a closely guarded secret. They use highly specialized equipment to make sure all the rods are consistantly the same chemical composition. It would be interesting to see flux core wire being made as well. Dave
Wild Bill
04-26-2007 20:32:54
 TELL ME ABOUT IT!!!!! in reply to Farmall MD nut, 04-26-2007 15:20:34
Yeah, sometimes I think your only "cool" around here if your name is "Oxidized International", or "Iowa Goatman", or "Alvin In ME". It's almost like the more you belittle new folks (or ebay) the "cooler" you are.
Boy I must be in some kinda mood tonight;)
Iowa Goatman
04-27-2007 16:43:57
 Re: TELL ME ABOUT IT!!!!! in reply to Wild Bill, 04-26-2007 20:32:54
What's wrong with Iowa goatman?
Wild Bill
04-28-2007 19:46:04
 Re: TELL ME ABOUT IT!!!!! in reply to Iowa Goatman, 04-27-2007 16:43:57
Nothing pard, LOVE the goat man!
Stan in Oly, WA
04-27-2007 13:11:37
Hi Wild Bill,
I'm not criticizing because I assume that it's me who's missing something here, but except for your last line I didn't understand any of that. I let a whole day go by in the hope that it would suddenly become clear to me, but I don't think it's going to. What do those names mean, and what new folks have been belittled? EBay? Some like it and some hate it, about like anything. (I like it, but so what?)
All the best, Stan
Wild Bill
04-27-2007 16:09:44
 Re: TELL ME ABOUT IT!!!!! in reply to Stan in Oly, WA, 04-27-2007 13:11:37
Exactly Stan, Have a good one ;>)
Clay in PA
04-27-2007 16:38:29
 Re: TELL ME ABOUT IT!!!!! in reply to Wild Bill, 04-27-2007 16:09:44
You make me laugh.
Stan in Oly, WA
04-26-2007 16:59:29
Hi Farmall MD nut,
Good point about the word wars; I'm not proud to say I'm one of the worst, if not THE worst, in that regard. Despite that, this is a pretty friendly site. We sometimes argue about each other's information, but rarely or never criticize or belittle anyone for their lack of experience.
What I've heard and found to be true about joining stainless to mild steel is that it doesn't matter whether you use SS rod or mild steel rod. At some point the two varieties of steel have to mix because that's what welding is. SS filler carries the fusion slightly further into the mild steel, and vice versa.
On a related topic, are you aware that if you use the same grinding wheel or disk, or the same wire wheel or brush on both mild steel and stainless steel, the stainless will lose much of its corrosion resistance? You need to have a new grinding wheel or disk which is used only for stainless, and your wire wheel or brush not only has to never be used on mild steel, but has to to be stainless itself.
All the best, Stan
Farmall MD nut
04-26-2007 17:27:57
 Re: New to forum, question w/o war, weld ss to ste in reply to Stan in Oly, WA, 04-26-2007 16:59:29
Hi Stan. Yeah, I kinda had the same opinion, shouldn't matter cause they both end up mixing anyway. I just didn't know if there was a better mix with different rods. As far as grinding and sanding pads go, that much I do know. You start grinding on stainless after steel, all those steel particals embed into the stainless then rust. Also a stainless wire brush. I see alot of people put a steel wire wheel on and then go to town. It's sure to rust. Thanks for the input, Farmall MD nut
Stan in Oly, WA
04-26-2007 21:11:52
 Re: New to forum, question w/o war, weld ss to ste in reply to Farmall MD nut, 04-26-2007 17:27:57
Hi again,
I was still in the process of writing my previous post when Dave, 135 Fan, posted his. Of the two of us, my recommendation would be to go with what Dave says; besides having a keen, analytical mind he has a wealth of real world experience (as do T_Bone, and DNWELDERMAN), while my hands-on welding experience is far less. I know from experience that what I told you will work, but Dave probably can tell you why the way he says to do something has a benefit that isn't obvious to someone who hasn't seen it in a variety of applications.
I generally use mild steel electrodes to join SS to mild steel, but I've never had to do so in an application where there were dynamic stresses involved. It could be that in that situation different factors would have to be considered. If it were my project I'd probably weld one up with 7018 and then torture test it beyond the limits you would expect it to encounter in use. If it held up, and the application wasn't one in which failure would be catastrophic, I'd go with it. If it was a structural component on something like a vehicle that was going to be used to transport nuns and puppies and orphans, I'd try to get some better advice.
When I weld rod together lengthwise I like to taper both ends, at least one end to a fine point, preheat a little, and be fastidious about not entrapping any slag. That generally takes care of it.
All the best, Stan
DNWELDMAN
04-27-2007 01:45:41
 Re: New to forum, question w/o war, weld ss to ste in reply to Stan in Oly, WA, 04-26-2007 21:11:52
Hey Stan. Thanks for the plug back there. I figured you guys'd still be mad at me. I've been on the road out of town past 4 days, haven't been on the forum. I acted like a jack-a@$ last week. Guess I gotta stay off forum when I have a bad few days. Sorry Stan, Sorry Dave... Have a good one. Doug
135 Fan
04-26-2007 16:42:35
Yes 309 is for welding dissimilar metals like steel to stainless steel. Make sure to wear eye protection. Slag on stainless welds can just ping off and fly right into your eye. Stainless welds really nice at the right heat. Grind a bevel on the pieces so you get good penetration. Dave
dan hill
04-28-2007 04:58:22
 Re: New to forum, question w/o war, weld ss to ste in reply to 135 Fan, 04-26-2007 16:42:35
I use stainless on a lot of repair jobs.I first used stainless on a new exhaust pipe that had to be shortened.Couldnt cut the end off because of a bend in that area.Used an old 30s stick welder 40 years ago.When my stainless rod supply got low I bought 30 lb on ebay for 3.50 per pound shipping included.Stainless is expensive, but you should try it on tough jobs.Watch yard sales for welding rod .I bought 30 lb of 6011 for 2.00
Farmall MD nut
04-26-2007 17:33:21
Hi Dave. Hey, Thanks for the slag warning, I think I've heard someone else say that too. Definately don't need slag melted to the eye. Thanks, Farmall MD nut
135 Fan
04-26-2007 21:27:06
 Re: New to forum, question w/o war, weld ss to ste in reply to Farmall MD nut, 04-26-2007 17:33:21
I've had some close calls with stainless slag flying off when it cools. 7018 can be used for welding steel to stainless if that's all that's available. Stainless is a stronger metal than steel so would offer a stronger weld when joining the 2 together. I remember back in high school we were bending stainless round bar around a pipe flange to make a ring. The teacher first said to use 7018 but then when he came over to show us how, he said it's better to use a stainless rod because there would be a lot of stress on the tack at the end of bar from putting a snipe on it to bend it. The bar was heated and we came out with a nice round ring about 8 inches in diameter. Dave
Bus Driver
04-27-2007 03:59:35
 Re: New to forum, question w/o war, weld ss to ste in reply to 135 Fan, 04-26-2007 21:27:06
Stainless stronger than mild steel? Stainless is for certain harder than mild steel, hence the thickness capacity for shears is less for stainless than for mild steel. But bolt strength charts show lower strength values for stainless steel bolts than for mild steel.
135 Fan
04-27-2007 15:56:08
 Re: New to forum, question w/o war, weld ss to ste in reply to Bus Driver, 04-27-2007 03:59:35
If you tack stainless together it's hard to break the tacks if you need to. Most of the super strength specialty rods are a stainless derivitive. Stainless is basically a low hydrogen process like 7018. Dave
Cliff (VA)
04-27-2007 05:29:31
Stainless steel cannot be hardened by heat treating. Thus the bolts have to be fabricated hard and worked hard (the working does provide some additional hardening however).
Plain steel bolts (with a little carbon in them) are worked soft (annealed) and then heat treated to harden them. Thus they are harder and have higher strength than stainless. Different levels of carbon and different heat treatment profiles give you the different grades.
Cliff (VA)
