Tool Talk Discussion Forum
gravity fuel tank
jddeere
04-26-2007 12:47:15
i bought a 300 gallon gravity tank a while back and i bought a new hose to put on it which i think is 10 foot. i just put fuel in it and im assuming the hose is to long because if u hold it down to the ground fuel will come out but if u put it up to the tank it will just barely come out. im guessing i need a shorter hose?
jeffcat
04-26-2007 21:27:37
 Re: gravity fuel tank in reply to jddeere, 04-26-2007 12:47:15
An awfull lot of those fuel filters need pressure behind them. Old trucks and tractors have screens and bowls. Remember that you get a couple of pounds of pressure for every foot of drop. That is why you get flow when you have the hose real down near the ground. Jeffcat
evielboweviel
04-28-2007 06:09:54
 Re: gravity fuel tank in reply to jeffcat, 04-26-2007 21:27:37
actually it is closer to 2.2 feet per 1 psi
Ron
Randy Losey
04-30-2007 10:54:26
 Re: gravity fuel tank in reply to evielboweviel, 04-28-2007 06:09:54
for each 2.31 foot you either gain or lose 1 p.s.i. depending on weather you are pushing/pumpin up or down.
jddeere
04-26-2007 16:39:35
 re ldj in reply to jddeere, 04-26-2007 12:47:15
what did u use to drop the filter down from the fluid level? i think i may try this..thanks
ldj
04-26-2007 19:09:41
 Re: re ldj in reply to jddeere, 04-26-2007 16:39:35
I used pipe fittings the same size as coming from the tank to filter, I believe 1". Out of the tank, then elbow and down, then elbow to level again and attach filter. If you need it can take photo and send.
L.D.
ebbsspeed
04-26-2007 13:18:56
I think "gravity" is key here. Gravity is what develops the pressure to allow the fuel to flow through the hose, and the closer the end of the hose is to the level of fuel in the tank, the less flow there will be. When they are equal, there will be no flow. Also, for gravity flow to work, there needs to be a vent in the top of the tank, Make sure there is, and that it is not plugged.
ldj
04-26-2007 13:14:17
I had the same problem with an antique visible glass fuel pump. Look back in search and around 2/20/07 , I think subject was fuel tank filter and you can read the whole thread and see if you think this will apply to you. Mine works good now.
