Tool Talk Discussion Forum
brunner compressor
chrisjimwa
04-25-2007 10:52:14
I have a Brunner compressor form Utica Ny Model #8621. Just want to know what oil to use in it, and anywhere I can get a pop off valve.
XRogerX
04-25-2007 20:55:05
 Re: brunner compressor in reply to chrisjimwa, 04-25-2007 10:52:14
Just use some good quality compressor oil and change it once a year, at least. Any decent hardware store should sell some. If you like, Shell Corena P122 is very good stuff. Mobil 1 full synthetic is also good. Pressure relief valves should be readily available from any local compressor shop. If there is one on your pump and it is blowing, you probably have bad valves in the compressor itself. Don't put anything higher than a 70 psi valve in the pump itself.
