Tool Talk Discussion Forum
Welder--how long can you weld-------
Leaky Boot
04-25-2007 04:34:58
225 Lincoln AC buzz box. How long can you weld one after another rod at 135 amps without having to worry with overheat. I've ran a bunch and did not seem but warm. Reason I'm interested is may do a project with about 200 ft of bead on plate so will be burning one after another. I knew one guy who said he never gave it a thought and just ran his all day with no problems. Any experiences and I don't mean reading the manual---real life please. LB
dan hill
04-29-2007 15:36:34
 Re: Welder--how long can you weld------- in reply to Leaky Boot, 04-25-2007 04:34:58
If you exceed the duty cycle you will burn the insulation coating on the windings and that will be the end of the welder.Only engine driven welders can stand contant welding. Make that 4 cylinder engine .There are some big tranformer welders that could do it but they are 3 phase.
Kevin (FL)
04-26-2007 14:54:09
LB,
Just curious about what exactly you'll be welding for 200 feet? Is it a butt joint or a fillet joint or what? Is it structure to plate? If the plate is thin, watch the shrinkage and warping and use strongbacks pretty regular.
Glen in TX
04-26-2007 08:39:53
The size of wiring and circuit you have to run the welder will affect it also. Input wiring too small and trying to push it and you'll find out and smell something burning. Large enough input wiring and circuit breaker or fuses and as short of cables on welder as you can will help with higher amp welding. I always try to keep it plugged in by box and cables short when doing hard surfacing on chisel shanks and such and still have to stop and give it a rest to cool off.
cannonball
04-26-2007 05:20:21
You can weld 100% at 75 and 10% at 225..i would not expect to get more that 50% at 135...try more and check to see if machine smells...you also must remember the outside temp makes a difference, the fan blows cooler air..you do have a fan running, right... mine stopped and had to take it apart and oil it..
MAY GOD BLESS THE USA
dave guest
04-25-2007 19:59:56
Wear gloves to prevent electrical shock. Welders get up to 40 or 50 volts, and always the surge could be higher. If you are old enough to remember the shipyards, lots of welders got electrocuted in the past. I have been shocked while welding and definitely try to wear gloves. Hard to remember at 64. Careful is the thing.
dave guest
04-25-2007 19:59:41
soundguy
04-25-2007 17:11:37
I got a hobart stickmate lx235ac last year.. I'm pretty sure the 100% duty cycle is available at either 90 or 100a and lower.
Soundguy
Willy-N
04-25-2007 12:00:11
Well I have over 280 ft of weld on 3/16" Plate building my Water Tender tank. I will say it was not done in a day(took a week to build) and I wore out before my Miller 225 Wire Feed did! Prep time, moving around ect seemed to keep things cool. That is a lot of welding to do in a row I went thru 2-35 lb roles of wire plus. Mark H.
Stan in Oly, WA
04-25-2007 10:00:14
Hi Leaky Boot,
Transformer welders that change amperage by some arrangement of a movable shunt will have a point at which the duty cycle is 100%. Often the duty cycle range is indicated right beside the amperage setting scale on the front of the welder. For a long time I believed that Lincoln's claim that the duty cycle of their 225 amp AC buzz box was 20% at every setting except one was based on uncharacteristic conservatism. To me this was reinforced by their claim that the duty cycle of the 75 amp setting was 100%. The 75 amp setting, the only one which is circled, is the setting they used to recommend for thawing frozen pipes. The welder hasn't changed but liability awareness has so Lincoln doesn't recommend that any more.
When I took a buzz box welder apart and really studied it I finally saw that Lincoln wasn't being modest about there being no higher duty cycle at lower settings. Their system uses taps at different places on the transformer. These are wires of different gauges which all connect to the back of the setting indicator which is a sort of movable switch. When you change settings you make a mechanical reconnection to a different tap wire. So each setting does in fact have its own 20% duty cycle.
When I was first trying to find out why these welders didn't have increasing duty cycle with decreasing amperage settings, many buzz box owners on this forum told me that they had never hit the limit with their welder and that I should'nt be concerned about it. Personally I've frequently tripped the house breaker when using the buzz box from a 30 amp dryer outlet but never had the welder shut down itself when running on a dedicated 50 amp welding circuit. Richard G's experience will make me be more careful about it in the future, though.
Any chance you could run your bead slower at 75 amps, maybe using 3/32"? That, supposedly, would give you a 100% duty cycle.
All the best, Stan
IH2444
04-25-2007 10:02:57
 Re: Welder--how long can you weld------- in reply to Stan in Oly, WA, 04-25-2007 10:00:14
I have a late 40's vintage Sears buzz box. It has a 90 amp 100% duty cycle connection on it. It is only a 185 amp welder but wieghs much more than my 225 lincoln....
Stan in Oly, WA
04-25-2007 11:47:49
 Re: Welder--how long can you weld------- in reply to IH2444, 04-25-2007 10:02:57
Hi IH2444,
What system of amperage selection does it use---plug-ins, sliding (handbrake style) lever, crank, or other? Do you think that the 100% duty cycle at 90 amps might mean that everything up to 90 amps is 100%? That's the way welders with movable shunt current adjustment work. If it has plug-ins like the old Forney welders then the current settings are wired to taps on the transformer the same as the Lincoln buzz box. External operation for current selection is different---plug-ins versus a click-in dial---but the mechanics of achieving different amperages is the same.
I owned a Craftsman 240 amp AC welder for a short time but I can't remember what the duty cycle scale on the face of the welder was. I remember that it was the pickiest welder about what electrodes it would keep lit of any welder I have ever used.
Currently I own a 185 amp AC Lincoln buzz box on which someone had written 1964 in pencil on the rod selection guide on top. It looks like every 225 amp Lincoln buzz box ever made except that the amperage settings on the dial only go to 185. It also doesn't have a fan but I can't tell from the internal wiring whether it ever did. I'll probably install a fan someday, even though it seems to do fine without one. It's one of the quietest welders I've ever used---not from lack of fan noise, but because it makes hardly any of that groaning transformer noise that most inexpensive transformer welders make so much of. I like it a lot but I can't really justify keeping it. It takes up space and I own several more capable welders. Oh well.
All the best, Stan
dan hill
04-28-2007 05:15:59
 Re: Welder--how long can you weld------- in reply to Stan in Oly, WA, 04-25-2007 11:47:49
Lincoln built the 180 when rural lines had a limit of 37 amps.The transformer had to be a good one and they used capacitors to correct the power factor.The 225 came out later and could draw 50 amps on the power line.I never seen a 180 but would like to own one, should be a nice welder.My 220 line measures 244 volts these days.
Mike M
04-25-2007 10:00:10
Won't hurt to check it for cob webs. Tip it over and clean it out and make sure your fan works good. Then I bet it will do all you will want at a time.
NEsota
04-25-2007 09:47:40
You might add some cooling fans. Plenty of them available from obsolete computers.
Richard G.
04-25-2007 06:14:27
Was building my gun safe years ago with my 225 Lincoln. Got in a hurry and did not give it time to cool down. Did not hurt the transformer but melted down the amp switching connections. 40 bucks.They are tough old machines but most have a 20% duty cycle. Weld 2 minutes and rest 8. That said, I have been using and abusing that old machine since 1977. Built over 50 wood heaters, made and repaired farm equipment and hundreds of other things. Just give it a rest once and a while to let it cool down.
Richard
Chris(WA)
04-25-2007 05:41:38
Weld away. At 135 amps and with the times it takes to change rods , move, catch your breath,etc. you will give the welder enough off cycle time.
mjbrown
04-25-2007 12:06:23
 Re: Welder--how long can you weld------- in reply to Chris(WA), 04-25-2007 05:41:38
Yep. 100%duty cycle is impossible to achieve with a stick welder.
dan hill
04-26-2007 02:20:56
 Re: Welder--how long can you weld------- in reply to mjbrown, 04-25-2007 12:06:23
The transformer would have to be built a lot larger and the welder would get heavy and cost more.
IH2444
04-25-2007 05:13:26
Umm each welder will have a duty cycle that varies depending on the heat range you are using.
unless I am mistaken an 80% duty cycle is based on a 10 min period. ie 8 minutes out of 10 you can weld.
Some welders are 100% duty cycle at some ranges.
Not sure on the Buzz box. I have one but no manual. At 135 mine seems ok to weld a rod or 3-4 and then chip off the weld and then go again for another 3-4 or so.
The lincoln duty cycle could well depend on if they are the older copper windings or newer aluminum ones.
Most of the newer small welders will just trip out if you exceed the duty cycle and get them hot.
Glenn FitzGerald
04-25-2007 05:05:40
I am not a production welder. I do not wear gloves while welding. My welder is set up with the factory cords and electrode holder. When the cord and/or electrode holder gets uncomfortably hot, I know its time to slow down a little. I have found a 20% duty cycle AC arc welder to be pretty forgiving. It's never slowed me down.
Glenn F.
135 Fan
04-25-2007 15:21:44
 Re: Welder--how long can you weld------- in reply to Glenn FitzGerald, 04-25-2007 05:05:40
You should always wear gloves when welding to protect your hands from uv and infrared rays. Dave
Taterchucker
04-25-2007 15:32:11
 Re: Welder--how long can you weld------- in reply to 135 Fan, 04-25-2007 15:21:44
Can it be that bad? I didn't think it would be. I've been putzin' around weldin' a couple hours a day for the last 5 years without gloves. Hands seem fine.
Tim B from MA
04-26-2007 08:38:44
 Re: Welder--how long can you weld------- in reply to Taterchucker, 04-25-2007 15:32:11
When I took my welding class several years ago, probably when practice welding on plate (which meant alot of welding during the 3-hour class) I was wearing a short-sleave shirt and got a "sunburn" on my arm ABOVE the cuff of the glove.
135 Fan
04-25-2007 17:18:36
That's what people said before they had skin cancer. Welding is the equivelent of bringing the sun 93,000,000 miles closer. I guess you can take your chances. Dave
Taterchucker
04-26-2007 01:17:00
 Re: Welder--how long can you weld------- in reply to 135 Fan, 04-25-2007 17:18:36
Wow, I didn"t know that. 93,000,000 miles closer? I know it gives you sunburn, but I didn"t know it was like that.
Stan in Oly, WA
04-26-2007 02:09:12
 Re: Welder--how long can you weld------- in reply to Taterchucker, 04-26-2007 01:17:00
Hi Taterchucker,
Possibly it's like bringing some, but not all, of the sun 93,000,000 miles closer. In any case, it can burn you in the way that increases your chance of getting skin cancer. Interestingly, while you can get a real burn from the rays of an electric arc, you can't get a tan. How does that work?
All the best, Stan
Taterchucker
04-26-2007 14:49:45
 Re: Welder--how long can you weld------- in reply to Stan in Oly, WA, 04-26-2007 02:09:12
Hi Stan. Yeah, I"ve noticed no tan after a burn. That is kinda weird. Is it a different kind of uv than the sun? Taterchucker
Stan in Oly, WA
04-26-2007 14:54:28
 Re: Welder--how long can you weld------- in reply to Taterchucker, 04-26-2007 14:49:45
Hi Taterchucker,
Yes. Welding arc UV is regular UV, while UV from the sun is SUV. Ha! (In other words, I don't know.)
Stan
Moe Libninum
04-25-2007 12:00:16
If you can run one rod, chip slag, wire brush and get another going repeatedly,
Eventually it will click off as you trip the internal device.
Once it starts happening the duration times will get shorter between the time it runs and is off, on standby, or just cooling down.
If you walkaway when it starts tripping and come back tomorrow it might run as long as it did today, or maybe not.
I know this because I have experienced it.
