Tool Talk Discussion Forum
compressor motor
MF294-4
04-21-2007 05:07:30
Can I take a compressor that has had a 10hp 3ph motor on it and put a 5hp 1ph and run it slower or less high pressure and have it work sucessfully? Can find a few good used 10hp compressors.
Areo
04-22-2007 18:04:55
 Re: compressor motor in reply to MF294-4, 04-21-2007 05:07:30
Some years ago when I was involved in a startup business venture we had an old 2HP compressor. After some time the pump died. Since we anticipated increased demand I got a 5HP pump and slowed it down as you suggested. It worked fine. Later when we needed more air we got a 5HP motor and were set to go. Your idea will work fine.
Areo
Ioway2
04-21-2007 16:38:15
I dont know where you are located, but I have a 7 or 7 1/2 horse motor that would work perfect. It is single phase, 1750 rpm on 220 volt. I do not know what base is on it, but I can get it for you if you are close to western Iowa. It is a big motor, not the newer style but a good motor. Is your compressor horizional or vertical?
XRogerX
04-21-2007 10:01:47
Depends on the compressor. That's a pretty big hp difference. Do you know what pump this is?
buickanddeere
04-21-2007 05:48:08
You can run the 5HP motor with the same speed pulleys as the 10HP motor. Just set the pressure switch to open when the motor reaches full load amps. Might only see 45 to 70 psi max however. Or drive the compressor at 1/2 speed. Just make certain you don't get too small on the motor pulleys and have to over tighten to avoid slippage. May need more belts? Or just purchase a 10HP single phase instead of always wishing you had in the 1st place.
mark
04-21-2007 13:03:45
 Re: compressor motor in reply to buickanddeere, 04-21-2007 05:48:08
go price a 10 HP single phase motor.
buickanddeere
04-21-2007 20:41:29
 Re: compressor motor in reply to mark, 04-21-2007 13:03:45
If he needs the capaicity, the price isn't much of a factor. There is a 10HP 1725 rpm Baldor 240V single phase sititng on the stable cleaner at home. Hasn't been powered up in 10-15 years.
mark
04-22-2007 08:42:02
 Re: compressor motor in reply to buickanddeere, 04-21-2007 20:41:29
buickanddeere,
are you interested in selling that motor? I have wanted one for a long time, but the prices I see always exceed my want factor!
buickanddeere
04-22-2007 19:14:48
 Re: compressor motor in reply to mark, 04-22-2007 08:42:02
$hipping from Ontario and border cro$$ing would make a new 10HP look good.
