Tool Talk Discussion Forum
Priming a Deutz aircooled diesel
Charles (in GA)
04-19-2007 20:49:26
I have a two cylinder Deutz (30 hp) in an Atlas-Copco 105cfm air compressor. It was low on fuel and I ran it for a few minutes and shut it down. Then a week later I was unable to start it, and topped off the fuel tank and still not luck. I pulled off the fuel lines from the injectors and no fuel is coming out. Anyone familiar with the Deutz know how to prime it? There is a lever on the side of the diaphgram fuel pump and on a Ford 3000 diesel that would be a priming lever, but it didn't seem to help on this thing.
I bought the compressor to run a sandblast rig (which I do not have,,, yet) and plan to use it with ground up corncob to blast the sorry deck and porch "stain" off my log house that the previous owner sprayed on it. The I can properly seal the logs with a decent sealer. I'm still looking for a decent sized pressure pot and blast gun, etc. probably something in the 60/80 gal range. I need to keep the compressor running and need to do some work to it also, such as changing the oil. Anyone know what weight oil this Deutz uses?
Charles
vitzarus
04-20-2007 02:54:33
 Re: Priming a Deutz aircooled diesel in reply to Charles (in GA), 04-19-2007 20:49:26
When it was low it may have sucked moisture -jell paste into some required screen and filter there to save your injectors. Where your hp fuel pump is there is a filter and some cutoffs which could be plugged. As I recall the manual prime can't suck through muck. Nice compressor!
