Tool Talk Discussion Forum
digital tach
jaker2
04-18-2007 08:12:05
I am looking for a decent digital tachometer to use on tractors. This tach does not need to be top of the line I am only going to use it occasionally. Has anybody bought one of the cheap $35.00 off of fleabay?
Local parts stores want about 150.00 for one. thanks JAke
KeithF
04-19-2007 05:46:38
 Re: digital tach in reply to jaker2, 04-18-2007 08:12:05
There is some information I want to pass along. If you put the solid wire core sparkplug wires on your tractor, the RF will be more than most digital meters can tolerate. It will make the readings eratic and completely unstable. Using an analog meter will solve it. The other option is to use the regular carbon filament sparkplug wires to tune with and then switch back. The latter is what I had to do with mine.
K-Mo
04-19-2007 04:27:38
Try www.jameco.com Jameco#: 645562
RoHS: No
MFG: VELLEMAN INC.
MFG#: DVM205AM
PRICE: $61.69
I don't have one but have been thinking about getting one.
K-Mo
Dave Anderson
04-18-2007 15:43:20
Snap on sells a handheld tach that you can use as a contact or non contact(laser) tach. I use it to find the rpms of attachments that I make for my skid steer loader. It's a little pricey ($300 4or 5 yrs ago), but its a tough, versatile unit.
John (MO)
04-18-2007 13:29:13
They work fine and last about 5/6 years. Then you throw them away and get a new one. You should also be able to pick one up at about any motorcyle shop. Just make sure you get one for a 4 cycle engine, they are different for 2 cycle and 4 cycle. I've got one one on lawn mower, ATV and tractor.
AJ in WI
04-18-2007 11:18:35
I purchased one of the $35 ones off ebay last summer. I set the RPM's on my JD A with it. My tractor was teched at a local tractor pull and my RPM's were right on according to the tech guys snap-on tach. I dont see any reason to spend more money for the same thing.
jack12345
04-18-2007 10:48:11
If its a tach that you are planning on leaving on equip, try Mini tach, I've have one on my sawmill for 10yrs now and still going,They are self contained and have other functions too count hrs etc.
John in CT
04-18-2007 09:46:21
I was going to buy one until I figured how to use my Snap-On digital timing light that has a digital tac in it for a Farmall H with a mag. Just hook up the pickup wire to #1 plug wire and power it using my jumper pack.
Daniel WI
04-18-2007 09:21:23
Just bought one for my Brother's tractor that I restored for him. Northern tool + Equipment it's a "DIGITAL HOUR METER/ TACHOMETER"
Displays RPM when engine is running and automatically displays run time in hours when engine is off. Also has a Programmable service check function with alarm for scheduled maintenance (Oil changes) $39 Iten# 160590-2705
