Tool Talk Discussion Forum
OT-95 Ford Manual Transmission
Chuck (VA)
04-17-2007 17:31:48
Been told that I need to change transmission fluid in '95 F150 with manual transmission. The fluid is a multi-grade ATF according to manual. Person told me said it gets condensation in it and will destroy transmission. Always thought these used gear oil. Only drive truck on weekends.
Is there an additive I should use when I change it this weekend to prevent condensation?
dave guest
04-25-2007 20:11:00
 Re: OT-95 Ford Manual Transmission in reply to Chuck (VA), 04-17-2007 17:31:48
Check trans often. That ATF don't stick around as long as the old 80-90W dope. A dry trans only lasts a little while and is darned embarassing. One summer I had 88 chev that ran dry. I was in a neighborhood where everybody was partying and setting outside bar-b-q in. That Chev locked up and started sliding and screaming and going sideways. All partyers thought I was on dope and ran in their houses to get away. Almost fun till I went lookin for another trans.
dave guest
04-25-2007 20:10:42
Charles (in GA)
04-18-2007 19:04:27
I have a '91 Ranger with the Mazda made 5 speed. the F150 tranny is a heavy duty version of this same tranny. Ford recommends 25,000 mi oil changes on mine. The original fluid came out black at somewhere around 25,000 mi. I did a couple of changes in a short period of time to get the crud out and only run AMSOIL synthetic ATF fluid in it. I was changing the fluid at 10,000 mi and then streched it to 15,000 and am now up to 20,000 mi. The fluid comes out clean and looks like new. The synthetic runs cooler and the transmission is as tight as when it was new, it has 220,000 mi on it now.
90wt Gear oil will destroy the syncros, don't even think about it. The thin fluid is used to allow for real tight clearances and fits and still have it function. ATF is not a real good lubricant and is a compromise between gear lube qualities and hydraulic fluid qualities. I cannot say enough for synthetics in this application.
I won't use anything other than the synthic AMSOIL ATF fluid, its cheap insurance, and easy to change. Go to an auto parts place and get a plastic gear oil pump that screws in the bottle and has a clear plastic hose with a barb end that snaps in the filler hole, makes refilling a snap. Mine takes 3 qts.
There are three rubber plugs in the back of the shifter rail holes. While kinda expensive at $7 each, they get hard and loose and eventually leak and can fall out. When this happens all the fluid is thrown out and you ruin the tranny. Keep good rubber plugs in it.
Charles
dds-inc
04-18-2007 18:16:40
ATF ONLY!!!!! !!! and if you want to, put a whole quart of some of that lucas oil additive for atf in it to make it stick to the gears!
Sand Flat Bob
04-18-2007 05:43:29
If you have a 5 speed, they all use ATF. Biggest risk is pulling a trailer in 5th, transmission gets very hot and burns the fluid, then there goes the transmission. Know, been there done that. Got very expensive. Don't use anything but ATF.
Bob
jack12345
04-17-2007 21:18:29
I have a 95 F150 and I do change the ATF in the trans and transfer case as stated in manual.Just change the ATF don't gamble on an additive,you can do job for about $30.00.
