Tool Talk Discussion Forum
Delta Shopmaster drill press set-up
cb in wsc
04-17-2007 12:13:08
My neighbor has on of these drill presses, and it keeps popping the belt off and he cannot get it to run at minimum speed. Anybody know how to set on of these up?
vitzarus
04-20-2007 03:59:00
 Re: Delta Shopmaster drill press set-up in reply to cb in wsc, 04-17-2007 12:13:08
You merely need to get the plane of the motor the same as the spindle or quill driving pulley. There are ways of tension and under that the angles change. Also the stepped pully of the motor may not be the same config as the orig which is at the spindle so some allowance to general center is made. The pully on spindle may have been flipped. The large dia is always at the bottom.
