I sure did not mean to say the blade backwards doesn't work. We used to do that all the time years ago, but a old guy told me to just try it with the blade in the wood cutting position. I would suggest everyone the next time just trying it. The biggest chance of climbing is on the industrial rib, and some that have a high tensil strength. Or the length wise cut where you have only a slight angle. Another advantage is when we cut on top of the roof without saw horses, and many times digging our toe nails in to stay on the roof. It is hard to control the saw real well. Some times it is best to not even try explaining a no calk lap on a valley to the guy on the ground. I would also suggest that on the job site, time is money so we probably get a little carried away at times going to fast with the saw, not giving it proper time to actualy cut the steel, thus a climbing action does indeed take place. I would like to also say that we all have heard that -- those old carpenders always did it just perfect when it comes to squaring up a roof etc. If that is so, alot of our comunity was build by inbreeds. Many times the line from point A to B gets a little crocked, and you need to climb over the rib. I guess if I did not have a calculator with a square root key maybe our projects would look that way to. We live on roofs sometimes, and some of these cuts get real trickey, so for the most part we cut face up so we do not screw up. I wondered also how many use the large rib panel shears to cut the steel to a proper length? We seldom do, rather we cut the whole pile (max around 40 sheets)at one time with a metal cutting cement saw. We just never had a uncluttered area that was level, and not on gravel. One of the best places to cut steel is in deep grass so the skill saw does not hit the dirt, nor do you scratch the steel. One time we cut a 5/8" copper gas line off that farmer Brown had never got around to digging in. No harm was done, no fire, we all three could have went to the eye doctor and not needed the eye drops to dialate our eyes. The devil will just have to wait for the next round.
