Tool Talk Discussion Forum
wire gauge
Hersel
04-14-2007 11:15:37
What gauge wire do I need to hook two 12 volt batteries in series (24 volt) to power a trolling motor?
Thanks
Matt in TN
04-15-2007 07:41:31
 Re: wire gauge in reply to Hersel, 04-14-2007 11:15:37
Minn Kota has a chart on their site that tells you how to select the right gauge wire for your application. I think it's located in the FAQ section.
dave guest
04-14-2007 15:40:42
Are you sure you want total of 24 volts? Most troling motors I use are 12 volts. Now you could put 2 batts in parallel(plus to plus and minus to minus)to get longer run time. Wire probably is least no. 10, but I'm not there. Could be no. 8 which is bigger. Marina or hardware store could advise ya.
dave guest
04-14-2007 15:40:11
Gerald J.
04-14-2007 11:38:26
At least as large as the wires going to the trolling motor.
Gerald J.
