Tool Talk Discussion Forum
Shop Smith
Stumpalump
04-14-2007 06:30:47
What I really need is a new drill press but I see a lot of Shop Smiths on Craigs list. How does the drill press function work as compaired to a regular drill press? Chuck Size? If I already have a table saw and don't plan on using a wood lathe would an older Shop Smith still come in handy.
JimDril
04-16-2007 05:12:21
 Re: Shop Smith in reply to Stumpalump, 04-14-2007 06:30:47
An old shopsmith, model 10ER, has a nice heavy duty table on it, not like the newer models. I bought mine back in 1959. Very heavily made. It's the original from the 40's. I use the drillpress several times every week.
KEB
04-15-2007 15:38:20
Stumpalump,
I have an ancient shopsmith that I've used a few times as a drill press. It works, within limitations. As Fawteen said, the table leaves a lot to be desired if you're doing anything heavy. If all I was drilling was wood, it'd probably be OK. I also don't remember being able to slow it down very far.
Watch Craigslist for a floor model drill press. I picked up an old Craftsman cast iron one off the Denver Craigslist for about $40 becasue it didn't work. All that was wrong was the switch in the motor was bad. There's a Delta floor model listed right now for $125.
Keith
Stumpalump
04-16-2007 21:01:31
 Re: Shop Smith in reply to KEB, 04-15-2007 15:38:20
You read my mind! How did you know I was near Denver? I bought that $125 Delta. He settled for 108 and is a nice heavy 3/4 hp unit. I used it to drill out some brake roters to fit a different bolt pattern already. I still want a shop smith. I wonder if the old ones are better than the newer ones?
Fawteen
04-14-2007 08:26:16
I have a ShopSmith Mk V.
When I was on active duty in the Navy, and my "shop" consisted of a 4x8 utility shed, it was a godsend.
Now that I'm "retired" and have a full size garage, and room for a real tablesaw and a miter saw, I use them for the bulk of my wood cutting needs. The SS still gets used in bandsaw, lathe and disc sander modes.
As a drill press, it's fine for wood (VERY handy in horizontal boring mode) and barely adequate for light work on 3/8ths or so metal. 1/2" chuck capacity.
If ALL you're looking for is a drill press for primarily metal work, I'd say keep looking. If the other functions are something you'd use, and the price is right, it's a pretty good machine.
Fawteen - didn't mention
04-14-2007 08:30:00
 Re: Shop Smith in reply to Fawteen, 04-14-2007 08:26:16
The problem with using the ShopSmith drill press on metal is primarily the table. It's not nearly heavy enough, and doesn't keep position very well at all, particularly if you have to put a lot of pressure on it. It's not very heavily built, and not nearly rigid for regular use as a metal drill press.
