I have welded aluminium with stick using AC current per instructions on the rod package. It was quite a splattery messy ordeal. As for running aluminium wire, I have always used DC straight,.030 or .041 hard alloy wire, with 100% argon at a high flow rate. We once experimented with 75/25 gas with aluminium wire on some scrap aluminium before changing over gasses, just to see what it would do. It was way too HOT. It just burned through the material and was extremely dirty. I'm with the AC/DC/CC/CV stuff and have several different machines that throw from any to everything. My little crackerbox I have mounted in the barn for quick patch jobs is an AC only machine. I have a wire feeder (spool gun), with its own contactor, gas valve and speed control box, that is not dependent on the welding current to operate the wire feeding functions. I originally set it up to run off a portable unit with no remote feature for one particular large outdoor aluminium job. The feeder drive is totally isolated from the welding power. I keep wondering what would happen running that feeder with AC besides a little less penetration and maybe more splatter. I guess maybe the only way to find out is to hook it up and pull the trigger.
