Tool Talk Discussion Forum
Welding question, sort of??
John in Ct
04-12-2007 15:20:25
I want to buy an infared thermometer but not sure of how high it should be able to read. So I was wondering, how high for a welding application is necessary. Say I would have to preheat something to X degrees before welding. The higher the thermometer goes, the higher the price. Thanks!!
DNWELDMAN
04-21-2007 04:07:28
 Re: Welding question, sort of?? in reply to John in Ct, 04-12-2007 15:20:25
Hi John. Generally you won't need to preheat over 400 degrees. It doesn't sound like you're going to do anything special, so 400 should be the highest you'll need. And also, Ususally, not always, Usually, you only need to take the chill out of whatever you're welding on. Meaning about 100-150 degrees or you get hairlines right down the center of your root. Doug
135 Fan
04-12-2007 16:57:24
Unless you are doing heat treating and stress relieving, you don't need anything near 1500 degrees. If you are forming really thick sections for vessels you need to go to 1650 degrees for hot forming. For a strictly preheating application about the most you'ld ever need would be about 650 deg. Even then that would be for a very thick section of chrome-moly or something. 250 to 400 deg. is a common range for preheating. Unless your material is over 1 1/2 inches you shouldn't need preheat unless the piece is really cold. You can also get tempil sticks which are like a crayon that melts at specific temperatures. Dave
jmixigo
04-12-2007 15:55:35
An that problem is compounded by the fact that most gauges are most accurate at or around mid scale. For welding and metal work-about 1500 degrees Fahrenheit
