Tool Talk Discussion Forum
Stick welding questions
Matt in TN
04-09-2007 16:06:13
I bought some new 6011's today, and while welding, or rather trying, to weld with them, all they want to do is catch on fire or stick to the metal. I'm welding 3/32" rod at 90 amps to .125 tubing. I've tried setting the welder from 70 to 100 amps with no better luck.
When I try the same exact thing with 3/32 6013's they weld like a dream.
What's going on here? I took the grinder to the metal to make sure I'm welding to clean material, but I just can't get these rod's to perform.
trucker 40
04-11-2007 08:38:49
 Re: Stick welding questions in reply to Matt in TN, 04-09-2007 16:06:13
6011 is push rod,you push the puddle,with 6013 you drag the puddle.Your biggest problem sounds like you are too hot,but I cant really tell.6013 might look good to you,but its not much of a weld.Your best bet is to watch somebody that knows what they are doing,as soon as you can.
135 Fan
04-11-2007 16:47:12
 Re: Stick welding questions in reply to trucker 40, 04-11-2007 08:38:49
6011 is a digging rod and usually the proper technique is to slowly whip the rod back and forth while progressing forward. The only actual rod designed for pushing would be a gouging rod. A good welder can have a rod at a push angle in a hard to reach joint but isn't actually pushing the puddle. With experience you can actually get the rod to fingernail on purpose so the slag stays behind the arc and out of the puddle. 6011 are very tolerant to welding over slag though. On something critical you'ld want to clean it first. Other rods would almost be guaranteed to have porosity or some other defect if you tried to weld through the slag. However when doing multi-pass fillet welds with 7018 there are times when you can leave the slag on. The work piece has to be very hot from a few passes and after the bottom pass of one layer has been done the middle and top passes can be deposited with out cleaning the slag as long as they are done one after the other. They do have to be cleaned before another layer of beads go over them though. Leaving the slag on, on the layers makes the passes flow together nicer for a very smooth fillet weld. For most of the welding that people on this forum will be doing, it is advisable to clean all passes. Hope you're all really confused now. I know I am. As Stan said, about the only time you push is when doing vertical up so the arc force keeps the puddle from running down and dripping into your boot. It burns real good. I know! Happy welding. Dave
Matt in TN
04-11-2007 10:59:25
While I'm no professional, I am hardly inexperienced. I've stuck my share of metal together over the past 15 years. Never, not once have I had a weld break.
My question was not an invitation for you to assess my experience or to convince me that a 6011 is exclusively a push rod. I know better.
Stan in Oly, WA
04-11-2007 09:57:25
Hi trucker 40,
When you give advice to inexperienced operators you need to distinguish between what has worked for you and what is considered standard practice. Specifically, no welding rods are "push" rods except in vertical up welding. MIG, TIG, and oxy all work fine either push or pull but with stick welding, particularly with rods that produce heavy slag cover, you increase the chance of entrapping slag when you push the puddle.
Once a person has gained a whole bunch of experience stick welding, as you have, it's reasonable for him to develop his own technique. Someone new to the activity, though, is better off learning to do it the way every source has taught it for the last 100+ years.
All the best, Stan
pvia
04-10-2007 14:36:56
Every electrode has its own chemical make up. They have a specific composistion for different grade metals to be used with.
The number on an electrode also has a purpose. It identifies what and how they should be used for. There are at least three pieces of information in each electrode number. For example on a 6010 rod the first two digits,60, represents the tensile strenght in thousand pounds. The third digit,in this example is 1, that indicates it can be used in ALL positions, flat, horizontial, vertical, and overhead. If it were a two it is for flat and horizontal position use(good luck welding overhead with it). The combination of the last two digits combined indicate coating type and useable current. In this case,10, is a celulosic-DC reverse rod. There is no rhymne or reason for this number and varies considerably. The iron powder low hydrogen rods (last two digits 18)must be kept in a rod oven or dried in one prior to use. If they are not dry they WILL cause gas out(porosity). Drying time should be 4 hours at 250 degrees.
I know we all have our favorite rods. Some weld "nicer" than others, others dig better, some chip easier, etc. There is "over lap" between different rods and they all will "weld" when put to the metal. If you want a good weld, do your homework, it may save you having to do it over again.
Tom Nelson
04-10-2007 10:28:49
Dirty, rusted and painted is the place to use 6011AC. Different brands have different welding characters, Hobart 6011ac has a much shorter arc length than Forney 6011ac at the same rod diameter and therefore is a bit tougher to use. Try some 7014 if it's a clean weld.
Tom
Steve Andersen
04-10-2007 06:58:27
Matt:
Sounds like youv'e experienced fresh 6011 acting like it should.
1. is your rod kept in a hot box.
2. do you know the arc voltage of your machine.
3.3/32"rod at 90 amps on 1/8" metal is right on!
4.6011...is a tough rod to weld with without experience.
40 yrs.in the building trades
Steve
135 Fan
04-10-2007 15:33:24
 Re: Stick welding questions in reply to Steve Andersen, 04-10-2007 06:58:27
6011 or 6010 should not be kept in a rod oven. They will dry out too much. Dave
big jt
04-10-2007 06:56:01
The other advice given is good. 6010 and 6011 are a fast freeze rod. good for working vertical or overhead because they freeze faster than other rods. One drawback to this is they take a EXTREMELY steady hand. If you are working flat use 6013 or my favorite 7014.
jt
Matt in TN
04-10-2007 04:52:47
Thanks for the advice guys. I'll turn the heat back and see how things work.
BTW, yes I'm running them on an AC only machine. The last batch of rods I used did fine, so I thought there was something wrong with the new ones. In the 14 or so years I've been playing around with stick welders, I don't recall ever having a rod combust like these were.
TomTX
04-10-2007 03:22:23
Try some 7014 and you will get much better results. Tom
135 Fan
04-09-2007 21:54:51
Generally if they stick they're too cold. If they catch on fire they could be too hot. I just did a deep penetrating weld with some 1/8 6010 on my backhoe bucket and put 7018 over top. I burned them at the same heat as a hot 1/8 7018. They were red hot and one big flame. If you're at around the proper heat and having problems try dipping the rods in water and drying them off again. 6011 and 6010 need some moisture in the coating and if they've been sitting around for a while they will get too dried out. Don't do this with any other rods. 6011 and 6010 are cellulose type rods which is kind of like paper. That's why they would smell like burn't paper. Try this and let us know. Dave
Stan in Oly, WA
04-09-2007 21:23:16
Hi Matt,
You didn't say whether you're running AC or DC. I'd guess AC because people usually use 6010 rather than 6011 when they have DC capability. On the other hand, 70 to 100 amps in only marginally too hot for 3/32" 6011 on most small AC machines but WAY hot if you're running it DC. I've never found the technical reason for that---maybe Dave knows---but it's certainly been my experience.
Anyway, when the electrode sticks and then immediately bursts into flames, that's hot. 6010 and 6011 tend to do that. They're great rods, though, in spite of being somewhat unfairly held in low esteem on this forum just because they make ugly welds and possibly because they stink (that's just a guess.) Good looking welds can be made with 6010 and 6011, however. When you can do that it's okay to think that you might be getting pretty good.
Here are a few other suggestions in addition to the good suggestions that have already been made. Make sure your ground clamp is tight and on clean metal. Start as low as 40 amps and don't increase it until you're certain that you can't establish an arc at that low a setting. Be ready to release the electrode from the electrode holder when it sticks---don't waste precious seconds trying to unstick the rod with current still flowing through it. Wiggling the rod with the electrode holder to free it when it sticks is fine if you have an unlimited supply of electrodes (and you don't mind that sour, burning newspaper smell.) Otherwise, get the electrode holder off, free the rod with your gloved hand, and start again.
If you're not using an auto-darkening helmet it's much, much harder to get it right. Don't practice on the work---practice on flat metal until you get the hang of it, then do practice fillet welds on scrap until you're good at that, THEN you'll be ready to weld your tubing.
Good luck, Stan
Tim B from MA
04-10-2007 08:58:03
 Re: Stick welding questions in reply to Stan in Oly, WA, 04-09-2007 21:23:16
Stan,
Is there an advantage to 6010 over 6011 if your welder is DC capable?
Stan in Oly, WA
04-10-2007 09:25:03
 Re: Stick welding questions in reply to Tim B from MA, 04-10-2007 08:58:03
Hi Tim,
Here, in full, is a posting from the Tool Talk Archives from 2002. The writer is Mark KW whose welding knowledge was enormous. He hasn't posted in several years now---much to Tool Talk's loss.
Stan
Mark KW writes:
Read the post on AC vs DC and saw the 6010 / 6011 debate show it's head.
For me, the 6010 has always been the "pipe rod" and personally I like the Lincoln 5P+. Smoothest running rod and well suited for low and high current applications. Flux slag nearly removes itself and they hold a super flat bead on horizontal joints.
The debate seems to arise when doing repair work, something I do a lot of. When doing new fabrication, the steel is clean and does not require a lot of prep and you have less chance of porosity and slag inclusions. Working on broken things is not as easy. You have dirt, oil, rust and a host of other things to deal with in the weld joint. Try as you may, in most cases, you simply cannot get all the crap out of the joint. The main thing I get is items that had been fixed before but not done properly. Most of the weld failures I see are caused by any or all of the following: Slag inclusions, porosity, poor fusion and or lack of penetration. Some welds are good but the joint was improperly designed causing the failure but that's another story in itself.
Slag inclusions are the hardest to deal with. In many cases you can't cut or grind enough of the metal away because of it's location or what not. Sometimes you have the option of carbon arc gouging the old weld out in order to remove the slag and get down to the base metal.
When you can't clean a weld good is where the 6011 comes into play. The flux ingredients on these rods will do a lot of cleaning if used right. The 6010's do not have the same flux coating composition and will not clean as well as the 6011's. Running 6011 DCEP (reverse) polarity, you can use a combination of technique and amperage to do a lot of things. Low amperage has less cleaning power but will allow for bridging wide open roots far beyond what a 70 or higher series rod will. Running at higher amperages, you can gouge and clean a weld as well as get a good root pass in all at the same time.
Granted I work on bigger machines, 100,000 pounds and up, so take this in the context of steel thicknesses. Normally I'll start out using the torch to remove as much of the old weld, slag and dirt as possible. Then grind clean whats left and go at it with a 1/8" 6011 around 130 to 140 amps for the cleaning root pass. Vertical up is the best if you can position the work to allow it, if not, overhead is second best choice. Gravity will help pull the slag and dirt out the weld so the more you can use it in your favor the better. Most times, I will always stay with a 1/8" rod unless I have stock over 1.5" thick in which case I'll start with a 5/32" or 3/16" 6011 running between 150 and 200 amps. The higher the amperage you can run without blowing through the better for cleaning. You will induce a lot of heat into the weld area which helps melt slag included in the old weld and also causes the flux to have a better blowing action to get the crud out of the root pass.
Second pass in a wide V groove on 5/8" or thicker stock is also done with a 6011 set at a lower amperage, 90-110 for 1/8", 125-140 for 5/32" and 130-165 for 3/16" all depending on how much cleaning and penetration I want get on the sides of the weld. Using second pass stringers on either side of the root is also acceptable for this but you need to get a good wash into the root to make it work right.
Follow-up filler passes are usually done with 7018, 8018, 9018, 10018, ect as required for the work and should be done when the root passes are still warm IE 400F or above to ensure good inner pass slag removal.
Given that most people deal with 1/2" or thinner materials, running a single good hot root pass with a 6011 on AC or DC and following up with one or two 7018 cover passes will usually hold anything the base metal will take. BTW, I did try some of the 7018AC rods the other day on an old Lincoln AC buzz box and they do lay a nice bead however, they do lack penetration you can get on DC.
Using 6010 for root passes on new fabrication is fully acceptable since you do need the full cleaning power. Penetration and weld bead specs for the 6010 and 6011 on new steel are about the same. When it comes to dealing with used equipment and broken welds, the 6011 has many advantages over the 6010. Not saying they won't work but in most cases you will find the 6011 will work a lot better for those weld you just can't clean good.
6013 is something I am not fond of. It'll do a nice weld on AC with the buzz boxes but is very easy to have problems with too. If you get 'em hot enough to get good penetration, you end up with a lot of spatter. If you turn them down enough to get a nice looking bead, you give up penetration and will also likely have a lot of slag inclusion if you lift the rod even a tiny bit. On DCEN, strait polarity, they will do OK but still have less than desired effects you can get from the 6011 or 6010. Someone suggested running the 6010 on DCEN but from what I have seen, this only gives a great risk of porosity and slag inclusion.
6011's will also run decent on buzz boxes too, just crank the amperage up and keep the arc tight. The tighter you hold the arc, the better the weld will be. If you can't feel the rod dragging on the stock without it sticking, you don't have enough amperage.
Not looking to start a rod war here, just giving my input on things having gone around the block a time or ten.
Mark KW
Tim B from MA
04-10-2007 17:32:31
 Re: Stick welding questions in reply to Stan in Oly, WA, 04-10-2007 09:25:03
Thanks Stan,
I remember Mark, he was (still is I hope :) big on cutting with oxy & propane.
Tim
135 Fan
04-10-2007 15:30:35
6010 and 6011 do have a slightly different type of coating. However 6010 have the most penetration. 6011 is close but not as deep, even if used on DCRP. 6011 rods were created so people who didn't have a DC machine could get similar results to a 6010 on an AC only machine. 6011 burn a little smoother than 6010 which some people prefer. For years the only 6010 worth buying were Lincoln 5P because every other brand would fingernail (coating doesn't burn off evenly). Hobart came out with a good 6010 that wasn't as deep penetrating as the Lincoln but ran a little smoother. I think Airco came out with some good 6010 as well. When Lincoln came out with the 5P+, they were a lot nicer to weld with than the regular 5P but it took a while for them to get approval for pressure vessels and piping because of something different in the flux that changed the composition of the weld metal. I can't remember what it was but was right at the time I was taking a pressure welding course. We could practice with the 5P+ but for the test we had to use regular 5P or Hobart. As far as rod numbers go the 3rd. number indicates the position only. The last number tells a whole range of info on the rod, the flux, the slag, the strength and the weld metal composition. As was mentioned 6010 are used for pipelines, not 6011. It would seem that the 6010 should be a better choice for other jobs as well. I don't see too many shops with DC welders using 6011. 6010 do code quality welds. If a repair is made on something that can't be properly cleaned out, you can't blame a failure because of the rod. Going over a 6010 or 6011 pass wth 7018 will give the most strength. Dave
Stan in Oly, WA
04-10-2007 21:43:16
 Re: Stick welding questions in reply to 135 Fan, 04-10-2007 15:30:35
Hi Dave,
It's hard to catch you in a mistake but I think you've made a small one this time. The second to the last number of the stick electrode designation indicates position, as you said. However, the information you said was provided by the last number (flux composition, etc.) is actually provided by the last two, unlikely as that seems. I'll bet you just misspoke.
I wouldn't bother to nitpick with anyone less precise---or less easygoing---than you.
All the best, Stan
DNWELDMAN
04-21-2007 04:28:02
 Re: Stick welding questions in reply to Stan in Oly, WA, 04-10-2007 21:43:16
Hi Stan. Dave is right. Second to last # is the position, and last # is flux composition. The only time two #'s are used together is the first two(or three in higher tensile stregnth). 60,70 80,etc are always the tensile stregnth. But don't get that confused with yeild stregnth. The tensile stregnth #'s are not always written in stone either. Depending on method(prep, preheat and so on) you can get a 7018 to hold 80,000- 90,000 psi. I've done this many times. 20+ years of welding. Doug
135 Fan
04-11-2007 16:21:10
To a very small extent I suppose. An example would be 7028 vs. 7018. Although they are both low hydrogen, 7028 can only be used for flat and horizontal because of a heavier flux coating containing more iron powder. If you went only by the 8 you wouldn't know they were different. The same could be said for 7024 and 7014. For specialty type low hydrogen rods more info is added after the last number such as -1 or C3 or in the case of stainless rods an L can be put after the first three numbers, which identify the type of stainless, to indicate low carbon or extra low carbon. IE/ 308-16 vs, 308L-16. The odd ball rods are the 7018 AC. They meet 7018 specs but are made specifically for use on AC machines. Not all of them say AC after the 7018. I have found that the AC 7018 tend to get porosity a lot easier especially if they are used on a DC machine. Kind of odd. When Hobart first came out with the AC 7018 you could restrike without having to knock the slag off the end. They worked great on AC but full of porosity on DC. I wish they could make a good 7018 that was easy to restrike without getting a little ball of slag on the end after welding. If only there was one good rod for everything. 7018 are close though. Dave
Tim B from MA
04-10-2007 17:37:31
Thanks to you too Dave, good info as always.
Tim
MarkB_MI
04-09-2007 17:41:36
6010 and 6011 take some getting used to, especially if you're used to "drag" rods like 6013 or 7014.
First, strike an arc like you're striking a match. If try to tap your work the rod will stick. After you strike your arc, hold the rod away from the work until the arc stabilizes and you start to get a puddle. Then you can start to weld. The tip of the 6010/6011 rod forms a little rocket that will penetrate deeply. Also, because the slag is very thin on a 6010/6011 bead, the bead will freeze very fast. It won't be pretty. If you want a pretty bead, try a different rod.
old
04-09-2007 17:22:48
For one thing your useing a setting thats way to hot and on thin stuff 6011 doesn't work well either.
mj
04-09-2007 16:31:42
Better check your lead connections to the welder. Sounds like you might have them reversed. Been there, done that.:-)
MPK
04-09-2007 16:20:38
I would guess you are running too much heat for 3/32 rod. That seems to happen to the rods when run too hot.
KEH
04-09-2007 17:09:27
 Re: Stick welding questions in reply to MPK , 04-09-2007 16:20:38
What MPK said, too much heat for that thin metal. Go below 70 amps. 6011 rods do a good job on rusty, painted metal and thick metal. 6013s are better for thin metal.
KEH
