Tool Talk Discussion Forum
circular saw question
n9lhm
04-09-2007 11:53:43
Here"s something I have always wondered about circular saws:
Why do direct-drive (cheaper) saws have the blade on the right and the motor on the left, while worm-drive (good) saws have the blade on the left and the motor on the right?
I"m left-handed, so the direct-drive saw is better for me so that I can hold the saw in my left hand and see where I"m cutting. I want to buy a new saw, and want to buy a good worm-drive one, but I won"t be able to see where I"m cutting if I hold it in my left hand. Whyizzit?
JOHN HARMON
04-11-2007 16:38:15
 Re: circular saw question in reply to n9lhm, 04-09-2007 11:53:43
Porter Cable has a "Worm Drive Saw" available with Blade on either side to suit your preference. I am right Handed so I have the one with the Blade on the right side.
Tim B from MA
04-09-2007 14:10:22
"Cheap saws" are available in right handed (blade on right) and left handed (blade on left); or at least Porter Cable makes left handed saws.
I would guess it is the same for worm drive, though I've never shopped for one.
BTW, you are using your saw backwards. I see advantages since you can see better, BUT - I have one of each, when I found the left-handed saw at a yard sale I was excited for exactly the reason you say you like right handed saws.
However, when I started using the left handed saw, I found quickly that my "holding hand" (in my case my left) and my body in general were a bit too close to the blade for comfort.
Now I mainly use it for when I need to cut close to something on that side, or if it happens to be closer than my right hander.
reply
04-09-2007 14:07:57
T'ain't so. Porter Cable Mag saw models are right and left hand.
http://www.woodworking-news.com/woodworking_tool_reviews-324mag.shtml
