Tool Talk Discussion Forum
Loud pool pump motor
Pool Man
04-08-2007 17:44:50
I have a swimming pool pump motor that is real noisy, Sounds like gravel is in it, I wanted to have it all fixed before warm weather gets here so this weekend I took it all apart,I blew it out with high pressure air and checked it all over, I removed the covers on both ball bearings and put some fresh grease in them (Which they didn't need ) The bearings are nice and tight with no signs of wear, I then put the motor back together without the pool pump attached and bench tested it, It's still as loud as a dump truck with sounds like it has gravel in it, the motor spins free and free wheels when you unplug it, nothing is hitting , rubbing or scraping inside the motor housing.
Any ideas at all on where this noise is coming from?
Thanks
Ichabod
04-13-2007 05:30:08
 Re: Loud pool pump motor in reply to Pool Man, 04-08-2007 17:44:50
Before giving up on the motor, are you sure it's not the pump? Couple days ago mine started making a lot of noise. Took the pump housing apart and found a half dozen acorns stuck in the impeller intake. The strainer basket had cracked and allowed some trash into the pump.
Ichabod
Bob - MI
04-10-2007 11:45:56
New motor is less than $50.00 at Surplus Center. Mine is getting louder too and I figured that would be the best way to go. Should solve the problem and get me through another 12 years of service.
bil b va
04-09-2007 10:46:10
if it is a split- phase or capacitor start motor it will have a centrifugal operated switch . the govneror like mechanism on the shaft inside the motor maybe making the noise .
Fawteen
04-09-2007 01:03:37
Any chance the pump is cavitating? They'll sound like a handful of pebbles in an empty soup can if they cavitate.
Check the pump inlet to make sure it isn't plugged.
Bob
04-08-2007 17:56:53
Replace the ball bearings.
dan hill
04-12-2007 04:30:59
 Re: Loud pool pump motor in reply to Bob, 04-08-2007 17:56:53
I would not mess with pool motors.There is to much chance for current leakage in an old motor.
