Tool Talk Discussion Forum
OT f-250 4x4 warn hub rotor brake job
Mort Adella
04-07-2007 19:35:08
I'm working on a 91 f250 4x4 trying to do the front brakes, but have run into an issue with removing the hub from the axle. The rotor is pressed onto the hub and I need it off.
I've removed the cover, and the inner and outer retainer ring things.
But the inner next section hangs up on the tip of the drive axle nub end.
Do I need to file off a ridge on end of axle nub, get/make a puller, or what?
Jim K
04-08-2007 14:27:31
 Re: OT f-250 4x4 warn hub rotor brake job in reply to Mort Adella, 04-07-2007 19:35:08
Did you remove the snapring from the end of the axle stub.
The one
04-08-2007 04:31:17
YOU NEED TO BUY A DODGE
Mort Adella
04-09-2007 19:36:05
 Re: OT f-250 4x4 warn hub rotor brake job in reply to The one , 04-08-2007 04:31:17
I'll answer my own question.
Now that the snaprings, and burrs are removed,
screw the outermost section halfway back on and smack that outward with a big hammer.
