Tool Talk Discussion Forum
Westinghouse Compressor 2YC
JSwartz
04-05-2007 12:28:17
I have the opportunity to pick up an old Westinghouse 2YC air compressor, dated 1947. It works well and was used until recently replaced by my company with a screw compressor due to increased air requirements. I'll need to replace the 3-phase 3 HP motor and it looks like parts are available if they are ever needed. Any thoughts on this compressor for home shop use? And how much should I offer the boss for it?
XRogerX
04-05-2007 18:21:17
 Re: Westinghouse Compressor 2YC in reply to JSwartz, 04-05-2007 12:28:17
That's an excellent pump.
It's also 60 years old.
Figure in the cost of a rebuild or a new tank before making an offer. Personally, I'd look for something newer if I couldn't get it really cheap.
Independent Components Corp. out of New York probably has parts for it.
IowayIHC
04-05-2007 13:56:43
I have a Westinghouse compressor that is probably of the same vintage. Twin cylinder,2 stage pump on a horizional tank. I sure would not trade it for a new oil less compressor. I gave $125. at an auction and it had a 3 ph 5 hp motor on it, which I replaced with a 5 hp 1 phase. I would let your boss price it first, and go from there. The large cylinder on mine is about 6 1/2 inch and the small cylinder is about a 3 in. That is not counting the fins around the cylinders. The cooling tube fins were excelllent condition. The only draw back is the 3 phase motor. My question to you is where did you find parts for these older compressors? I have not tried to find parts and do not need parts, but if it ever happens that I do, it would be nice to know where parts are available. Thanks and try not to let it get away.
