Tool Talk Discussion Forum
Work bench
Maark
04-04-2007 11:55:57
Is there a standard height for a workbench in your shop or garage?
CDR
04-05-2007 18:21:16
 Re: Work bench in reply to Maark, 04-04-2007 11:55:57
I read somewhere years ago that the ideal height for a workbench is the measurement from the knuckles of your loosely curled hand to the floor when you're standing up-right but relaxed. That's how I did mine and it's short enough I can lift some pretty heavy parts onto it but it doesn't kill my back when working on something.
big fred
04-05-2007 07:45:30
Mine are 44 inches. My kitchen counters are at 40 inches. I can't imagine working for very long at a 36 inch bench unless you're a midget.
chvet73
04-04-2007 19:29:45
36" is standard kitchen counter height.
James in North Carolina
04-04-2007 18:30:19
I found a kitchen counter that was a comfortable height for me and made my work bench the same height. Seemed like the easiest way to go.
Wardner
04-04-2007 13:08:54
My work bench is hydraulicly adjustable for height. It is 4'x4' and is actually the floor for an elevator to a loft and the second floor of my barn. If I need additional temporary floor space it can be lowered so that it becomes flush with the floor. One hand-tightened 3/4" bolt secures the vise. The "bench" can lift at least 4000 pounds.
It is usually around 30"-36" high. During the cold weather, I store firewood underneath.
If you want something like that, you could use a forklift mast or an elevator for wheelchairs. The hydraulics can be fitted with a selector valve to run a press.
Tim B from MA
04-04-2007 12:38:00
Use the same height as your kitchen counter tops. I think its' about 32 to 34 inches. If you are taller or shorter than the average Joe, adjust accordingly.
dan hill
04-04-2007 17:01:19
 Re: Work bench in reply to Tim B from MA, 04-04-2007 12:38:00
Height is critical, too low will give you back pain.Start high..
Stumpalump
04-04-2007 21:40:47
 Re: Work bench in reply to dan hill, 04-04-2007 17:01:19
I like high also.
