Tool Talk Discussion Forum
air compressor revisited
cj3b_jeep
04-04-2007 11:53:56
I posted a few months ago about taking my air compressor apart, cleaning it and painting the inside of the tank with rustoleum rusty metal primer. I started the job the other day and it's going well. There was a huge amount of crud (which was eating regulators) in the tank due to he fact that the drain was non-functional. It's a bear to clean inside of, but I soaked the inside with diesel fuel, and have been using a water hose and various tools to clean the bits of rust and flaked paint out of it. I'm going to rinse it with denatured alcohol to clean out the diesel residue. It's still pretty solid as it's had 120 lbs of pressure in it all winter with no leak down.
My question is do you think Rustoleum rusty metal primer is the best solution for inside the tank or should I be thinking of something like POR-15?
cj3b_jeep
04-12-2007 10:22:12
 Re: air compressor revisited in reply to cj3b_jeep, 04-04-2007 11:53:56
I bought the grey POR-15, hpefully it's anough to coat the whole thing twice.
Kendall
04-05-2007 18:15:36
I"d use the POR-15 or KREEM. The tank cleaner in the Kreem kit is phosphoric acid, avaliable at good hardware stores. Either will seal the interior better than paint.
Nat 2
04-05-2007 12:05:23
Primer won't seal the metal against moisture, and it will soon begin to rust all over. You need a good finish paint to seal the surface.
