Tool Talk Discussion Forum
3-brush generators
JGShivers
04-03-2007 19:48:54
if a 3 brush generator field is grounded externally through a resistor, what is the value in ohms of that resistor? this resistor is usually located on the back of the rotary light switch, if so equipped. when the switch is turned "on", the resistance value is changed, or shorted out to provide a higher charge rate for the lights.
this is on a 6 volt system
dan hill
04-04-2007 17:13:29
 Re: 3-brush generators in reply to JGShivers, 04-03-2007 19:48:54
A 3 ohm 25 watt resistor will do. Shorting out the resistor will put the generator on hi charge.Jd switches are up to 85.00 now, last one I bot was 11.00.
John T
04-04-2007 08:23:32
JG, As you may or may not already know, the current output on a 3 brush generator can first be controlled/limited to a certain degree by the location of the third adjustable brush if so equipped. The higher charge rate is achieved by setting the third adjustable brush closer to the fixed brush located next to it.
On the light switch type of generator regulation my best guess is (depends on the particular genny) the value of the fixed resistor is somewhere around 1.5 to 3 ohms and, of course, the lower the ohms the more genny output, so you may wanna try 3 first then work your way down to 1.5 to see at what rate she charges with it in the field to ground circuit until you get the rate desired. You could use a series or paralell combination of a couple low ohm power resistors similar to an ignition ballast resistor which are somewhere aorund 1.5 to 1.85 ohms n see what charge rate you get !!!!! Let us know, best wishes
John T
Tom 43
04-04-2007 08:13:04
Good question!
Find an H or M Farmall with a cut out relay system instead of the combination cut out voltage regulator system an measure it with an ohm meter. I think Farmall changed in late 1949 or early 1950. Let us know what you find.
souNdguy
04-04-2007 07:41:33
I've seen 2 brush systems with tickler resistors on lamp switches. but can't say that I've seen 3 brush systems like that.
In any case.. low ohm values will be used here.. think in the 1-5 ohm value, depending on your specific machine.. and what charge level you are trying to achieve..
Soundguy
