Tool Talk Discussion Forum
What size drill bit
old
04-01-2007 20:49:58
Do I need to use when tapping for 1/4 inch bolts? Also how strong will the tapped holes be in 1/8 inch iron?? Would hole like that and then tapped for 1/4 inch bolts be strong enough to hold roofing metal on my hay barn. Right now I have been drilling 1/4 inch holes and useing bolts but at times its hard to get the nuts on to them because of how wide the metal is and its hard to be on both sides of the metal at the same time.
Thanks
Billy NY
04-02-2007 11:12:21
 Re: What size drill bit in reply to old, 04-01-2007 20:49:58
Self tapping fasteners such as Hilti, Drill Flex or many others would make this fastening a lot more productive I would think. Probably need one with the rubber washer for the roof and you can also put a dab of silicon over it, if the surface is clean around the head of the fastener, if old material, it's more work to prep and do this, washer ought to hold, it's not necessary, we used to hit all fastener heads with silicone in many assemblies that need to be water tight, but for this it's probably overkill.
Throughout my career in high rise building construction, fasteners become an intregal part of the job, so if your are involved in fastening details you get a great education on the subject and every job you learn something new, it can be a lot of fun sometimes, other times a nightmare but is great experience.
Mild steel + roof panel, + whatever else makes up the thickness, should be a lot easier to do with a self tapping fastener. 1/8" mild steel used a as a fastening substrate is plenty of thread engagement and provides great pull out values for each fastener, see below:
A #10-16 fastened into 10 ga.steel ( 1/8" I always forget) would give an average ultimate pull out value of 1,970 lbs., use 5/32" steel and that increases to 2,100 lbs. A #12-14 into 10 ga. steel would give you 2,180 lbs. My Hilti book is 6 years old, but I just used it for an example. A fastener similar to Hilti's HWH Kwik seal would seem to be ideal for this, whatever you can find locally, although I do see some deals on hilti materials on e-bay. A quality manufacturer is best, they perform better, but there are many manufacturers of these and you might find something locally that will suffice.
Rule of thumb: The thickness of material being fastened and the diameter of the screw determine the type of thread pitch to be used. In general, the thinner the fastened materials the fewer number of threads. The thicker the material the greater number of threads.
The only thing with these fasteners is that you do need to be able to put a little pressure to get them started and thicker steel like 1/2" is more difficult, certain rpms work better according to the rep I used to deal with. If need be you can use a pilot drill just to get a clear hole through, they will zip in real easy if you do this, but it really is not necessary, 1/2" steel we used to do it sometimes. It would defeat the purpose of the self tapping fastener to have to pilot every hole.
Compared to drilling and tapping, then fastening, I think yo may find these much quicker to install. It ought to seat into the roof panel, which will hold it in place while it drills through the mild steel, then it will grab and seat, don't over do it, good to have driver with a clutch on it so when it's torqued just right it lets off, can do it by feel too but properly done, it's strong, I can think of a lot of places on buildigs I'd preferred to have bolts, but self tapping fasteners were used and or specified. For the size they perform well in shear and tension.
All of this is a little overboard on the technical aspect, it was one part of my job I did like, solving fastening problems and designing details for an engineer to check, doing pull out tests with suppliers etc.
#10-16 or similar, length as per your thickness would suffice, they have #12's and 1/4" diameter fasteners, the use of these is not much different then attaching metal decking to structural steel, for the concrete slab, sometimes they do use mechanical fasteners, other times tack weld it, depends on what is called for on the drawings.
A self tapping fastener also eliminates doing any work on the underside of the roof panel, as you mention using standard capscrews (bolts) and using nuts on the other side.
Don-Wi
04-02-2007 09:49:05
A 1/4-20 uses a #7 drill. I can"t off the top of my head remember what a 1/4-28 would need, which is what I would recommend if you can"t put a nut on the backside. In 1/8" steel a 1/4-20 won"t have much hold, the threads will pull pretty easy, seeing as you"ll only have at most 2 1/2 full threads. A 1/4-28 would atleast give you 3 1/2 threads.
Donovan from Wisconsin
glennster
04-02-2007 09:13:41
how bout usung pop rivets? you can get em in steel, aluminium or stainless. set em and put a gloop of silicone over the top to keep em waterproof.
Don L C
04-02-2007 07:18:18
OLD
I would use stainless seeel 1/4" or 5/16" self starting bolts....use a drill motor and socket to fit..... 1/8" bit for a starter hole if needed.....you may have to order the stainless bolts..... ..... ....Don
flying belgian
04-02-2007 03:51:19
You will want to use fine threaded bolt. Will get more threads in 1/8 inch.
machinist guru
04-02-2007 02:52:26
FOr 1/4" 20 unc screw the drill size is #7 bit (.201) and for the 1/3-28 unf the drill size is #3, I suggest using the #3 drill for 1/8" iron. this will give about 3 threads in the 1/8" iron. (not much)
Wardner
04-02-2007 00:08:34
All you have to do is "google" on 'tap drill size' and you will have at least a dozen sites to look at. They will all have the drill size tables.
Moreover, if you need either the tap or drill, any hardware store will sell a combo kit that include both peices in one package.
Owen Aaland
04-01-2007 22:28:15
Have you looked into using self-drilling self-tapping scews? They are made for attaching roofing and siding on steel buildings. They come with sealing washer on them to make them weatherproof.
TimV
04-01-2007 21:09:52
Rusty's right--it is a #7, assuming you're talking "normal" 1/4-20 bolts with normal thread engagement. Could you use self-tapping screws, even if you had to pre-drill them first? 1/8" isn't a lot to hold unless you put quite a few in.
old
04-01-2007 21:59:32
 Re: What size drill bit in reply to TimV, 04-01-2007 21:09:52
Ya I was thinking it would be enough but at least if I tap each hole I can then go back after words and put nuts on them from under the roof. Some how its just to far to reach 3 foot when your on top and the roofing is 3 foot wide. If I'm lucky I'll have this thing done by the time I'm ready to do the hay, but so far I have all of 12X16 of roof done and I have been working on it all of march. Sure wish I could work like I did back before I had my back problems but oh well I get things done even if it takes me 10 times longer to do them.
Thanks
Slowpoke
04-20-2007 00:38:41
 Re: What size drill bit in reply to old, 04-01-2007 21:59:32
I think putting nuts on the underside could cause the bolt to back out unless it's held from the outside. Try it on a sample of your material. If it backs out, your stuck.
Bill in NorthCentral PA
04-02-2007 04:39:14
Old,
Seems like I remember where someone (you - can't remember) was talking about roof pitch. If the roof is 4:12 or less, screw the end of the sheets and then you can place weight on the sheet to reach the other side.
I second the vote for self-drillers / self-tappers. Check out Dynamic Fastener or Fastenal for sources. Spin the screws slow to allow the tip to drill. They are easy to use when you get the hang of it - but most guys burn up a couple learning.
Hope that helps.
Bill
RustyFarmall
04-01-2007 21:04:17
Rich, I think it is a #7 drill bit. I'll verify that tomorrow when I get out to the shop.
GeneMO
04-02-2007 09:42:16
 Re: What size drill bit in reply to RustyFarmall, 04-01-2007 21:04:17
The self tapping barn metal screws would sure work nice, they have a rubber washer. They are a little pricey but work real nice with a cordless drill.
Barn Metal Fabricaters here in Boonville sells them, as do other places.
Do your bolts have a rubber washer, like the old grain bin bolts?
Gene
old
04-02-2007 11:58:58
 Re: What size drill bit in reply to GeneMO, 04-02-2007 09:42:16
No rubber washers on any thing I'm useing. This hay barn is being built on a penny budget, so if it cost more then a penny its no going on it. I have lots of scrap roofing and lots of scrap metal laying around and I need a hay barn so I figure what the heck any roof is better then no roof. I figure after its built I'll coat the roof with a roof coating so it doesn't leak as much. I'm tired of haveing my hay and tractors in the same building. I figure when I get it done which will probably not even be this summer it will have cost me less then $500 and that figure is probably high. So far only things it has cost me is bolts and welding rods and the gas to run the welder
vitzarus
04-03-2007 02:10:51
 Re: What size drill bit in reply to old, 04-02-2007 11:58:58
I wish you well and good advise here. If you have a couple of drills really go with them fastenells type. Locate and drill a pilot hole about 1/8" then you just power in a self drilling fastener.They may be a little expensive but you didn't catch the right yard sale.If a box costs 26.00 and saves your back it's a bargain.I have a feeling once you use them you will continue that way. 1/4 is max. 12x24 or even 10x24 is good for 1/8 but you know where one is better than another.Up there tapping holes don't make no sense.
