Tool Talk Discussion Forum
armature grinder belt
SDmechanic
04-01-2007 20:04:03
I need a armature lathe belt. It is 1/4 wide and is round. I was hoping someone on the board would know of a source for such belt. Or if any one is interested in buying this lathe I would consider selling. Thanks for your reply.
Glen in TX
04-03-2007 09:20:22
 Re: armature grinder belt in reply to SDmechanic, 04-01-2007 20:04:03
I had one of those Tru Cut belt drive armature lathes once and had to almost give it away to get rid of it. Machine dealers don't want them. Armature work dust is hard on a lathe and you are better off to just find a small older regular metal lathe and keep it dedicated for armature work only. If yours has the undercutter on it and not worn out keep it for your own use as I doubt it would bring over $150 if that.
Earl-IL
04-02-2007 12:47:52
McMaster - Carr Has what you need . Listed under Round Belts 404-346-7000 or www.mcmaster.com on line.
Owen Aaland
04-02-2007 07:02:10
I checked the size of O-ring on my lathe. Five inch OD.
Mine is a "TruCut" brand lathe. The O-ring is used to drive the undercutter only. To turn the armature it uses a flat belt. One inch wide, 9 1/2 inches long.
Jim Rockwell
04-08-2007 12:44:57
 Re: armature grinder belt in reply to Owen Aaland, 04-02-2007 07:02:10
Hi Iwas doing a search on the trucut armature lathe.I found a place that has parts for the lathe I believe. Here is the link:
Link
Link
If you use the second link click on electrical,hopefully that will help some of you guys out. Now I have a question that hopefully somebody can help me out.If somebody has a copy of the manual for a Trucut Armature lathe I would greatly appreciate it if somebody could scan it and email it to me or copy it and mail it to me. I'll pay postage and any reasonable fee.Thanks Jim [email protected]
SDmechanic
04-03-2007 10:22:06
Thanks Owen for the information. Your great and so is this board. Appreciate it very much. thanks again.
jmixigo
04-02-2007 02:58:06
Also check with janatorial supply houses, the belts used on the beater bars of commercial vacuums are about that size. Let us know the length, width an thickness somebody here will know where to get it.
Owen Aaland
04-02-2007 00:28:12
The round belt on my lathe is just an O-ring.
Jon Hagen
04-01-2007 21:45:17
You might still find that round belting at a sewing machine shop,especially if they stock parts for commercial machines. Used to be a common item with the ends coupled with a metal clip.
