Tool Talk Discussion Forum
Sump pump cure
Griz
04-01-2007 15:28:27
Power was out again. Got the generator fired up just in time to prevent flooding. I needed an emergency backup. I had a battery backup in my old house. It was a 12v DC powered pump. Piece of crap. With a full charge and a heavy rain, it couldn't keep up. I checked out the water powered pumps. I'm not so sure they could keep up. Cost a lot of money, could be iffy.
Got an idea to build my own system. I'd need an inverter, huge relay, starter solenoid and more. it occured to me that I was building a UPS "uniterruptable power supply". All I needed was a used UPS and probally new batteries. Found a 1420w UPS at a used computer store for $20, batteries from W-Mart for $160 and three cables. I did buy a new pedastal pump. It draws about a third the current of the old submersable. Works like dandy. Unplugged the UPS this weekend to get an idea of the number of cycle it could take. It cycled over a hundred times and still had 40% of it's power left when I plugged it back in. Problem cured.
Jim Krapf
04-02-2007 17:39:22
 Re: Sump pump cure in reply to Griz, 04-01-2007 15:28:27
Just threw out two of them at the hospital I work at. We swap em out every couple years cause we are trying to keep up with the times.
One was good for 7000 watts.
Dusty MI
04-02-2007 06:31:46
I found a better cure. A drain tile that is lower than my basement.
