Tool Talk Discussion Forum
Lighting
Larry Weeden
03-29-2007 10:10:38
I have a 1948 8N Ford Serial# 51988 and am looking for the original configuration of the lighting. Obviously two are headlight's up front but what about the rear? Was there one work lamp and one tail lamp assembly? This tractor is a restore project and came with no lighting . Any reply will be appreciated.
Rgds
Larry
Gerald J.
03-30-2007 10:36:59
 Re: Lighting in reply to Larry Weeden, 03-29-2007 10:10:38
I think the rear lamp may have looked like a 4" sealed beam fixture, but it had a three position switch on it. Toggle switch. One position, white light for work. Center position off, other position red. The sealed beam lamp had a clear part of the reflector with a red coating and a second lamp to make the lens glow red, The red coating could have been on the second lamp.
I don't have any 8N information, since I included it when I sold the toy years ago.
Gerald J.
Bob
03-29-2007 10:48:01
AFAIk; the lights were a dealer or owner-installed option and were installed in various configurations.
I wonder if John Smith's site has any details? It might be worth taking a look.
Larry Weeden
03-29-2007 11:09:01
 Re: Lighting in reply to Bob, 03-29-2007 10:48:01
Thanks Bob, I looked at the site you sugested. It appears that a tail lamp mounted on the left fender was OEM and the work light was optional as you thought. Thanks
Larry
PS. Any opinions on after market hood"s ? Mine has rusted through on a small section of the rib on both sides.
Slowpoke
03-30-2007 00:33:55
 Re: Lighting in reply to Larry Weeden, 03-29-2007 11:09:01
The rust is typical of those old Fords. Mine is the same. Welding new material in may be the answer. There are welding aids that will hold two sheet metal edges close together for welding flush. Unfortunately, the rust is usually on the rib area.
Larry Weeden
03-30-2007 06:12:37
 Re: Lighting in reply to Slowpoke, 03-30-2007 00:33:55
Thanks for the sugestion. I am going to look into that. My 1st choice would be to salvage the original rather than use an after market hood . I"ve heard that they arent always true and take some tweaking and suspect the gauge of the sheet metal is a bit less than the original.
Bob
03-29-2007 11:23:59
Sorry; I can't help you on the aftermarket hoods; as I've never used one.
I have a tractor with a hood damaged like your's; and a spare hood smashed at the back. Someday I intend to "hone" my bodyworking skils; which; too; have gotten rusty over time from "non-use" and attempt to splice the good parts together making one good hood.
