Tool Talk Discussion Forum
new compressor wiring
ross in ns
03-29-2007 04:19:50
hi all got new compressor the wiring to the new switch is different than my old one old one has 2 hot one netural and one ground red white black and the copper one new one has black white and green how do i hook this up thanks
buickanddeere
03-29-2007 19:19:57
 Re: new compressor wiring in reply to ross in ns, 03-29-2007 04:19:50
Sounds like the old compressor used a 120V control circuit similar to a clothes dryer. The new compressor either does not have an electrical control circuit. Or the control circuit is 240V. What HP and what kind of a motor starter?
RayP(MI)
03-29-2007 05:22:36
Sounds like old one is for 220v, new one for 110v.
suggest you take old one in and get exact match, return new one for refund.
Bus Driver
03-29-2007 05:06:54
More information is needed. Voltage and amperes on the new unit? Wire gauge for the existing wiring? The fact that you did not already recognize the need for this information really concerns me with regard to do-it-yourself wiring. Electricity is one of the most potentially dangerous things that we deliberately put in our buildings and residences. Errors can be deadly.
steveormary
03-29-2007 07:10:28
 Re: new compressor wiring in reply to Bus Driver, 03-29-2007 05:06:54
ross
There should be a name plate on the motor that will give you the voltage and amperage of the motor. Get back to us with that and mabe we can be of better help.
steveormary
