Small Engine Flywheel Removal
Brian G.
05-07-2001 07:13:18
An old mechanic with years of experience showed me the quick and easy way to remove flywheels from B&S and Tec. engines. Remove the nut and washer, find a socket slightly larger than the crankshaft end that will contact the tapered steel flywheel hub and give it a "sharp" rap with a hammer as if to drive it on. This will temporarily expand the hub and it will spring back and "pop" right off. Usually works with the first rap if done with "feeling". Same thing works for removing tie rod ends from spindles; after loosening nut, give the very end of the spindle arm a sharp rap and the tie rod end pops right out.
