Tool Talk Discussion Forum
Case VA carrier question
Rick Simmons
03-28-2007 14:36:55
I am re-installing the bearing carriers on my VA. The manuel says to use a T-109 sleeve on tracors with disks brakes. I tried installing them without using this tool since I don't have one and I can't get the carriers to seats all the way. Can anyone tell me exactly what this T-109 sleeve is suppose to do and maybe I can make one? Thanks
Slowpoke
03-29-2007 01:09:32
 Re: Case VA carrier question in reply to Rick Simmons, 03-28-2007 14:36:55
Maybe someone on the Case board knows.
Rick Simmons
03-29-2007 10:30:35
 Re: Case VA carrier question in reply to Slowpoke, 03-29-2007 01:09:32
How do you reach someone on the Case board?
Slowpoke
03-29-2007 10:55:32
 Re: Case VA carrier question in reply to Rick Simmons, 03-29-2007 10:30:35
Look at the top of your screen....above the red band that says "Tool Talk Discussion Board". You will see a grey band with various tractor brands. Click on Case on the left side and it will take you to a page where you can choose to go to one of the lastest topics or directly to the discussion board.
I have a 50s VAC, but my books and the tractor are 120 miles away. At the price of gas, ($3.10 and up near San Francisco) I will seldom get to see it. These oil companys are killing life as we know it.
Rick Simmons
03-29-2007 19:45:45
 Re: Case VA carrier question in reply to Slowpoke, 03-29-2007 10:55:32
Finally fiquered out what I was doing wrong. Jacked up rear of tractor,so wheels could rotate, which turns gears and lets you line every thing up. I still can't fiqure out what that tool would be used for.
mj
03-28-2007 18:50:00
You've seen the picture in the manual, right? I've never had or used one but it looks like it is for alignment during assembly but ????
Rick Simmons
03-28-2007 19:46:20
 Re: Case VA carrier question in reply to mj, 03-28-2007 18:50:00
I have the seal on the shaft, it just won't seat all the way back.
