Tool Talk Discussion Forum
Welding question
old
03-28-2007 11:36:01
When welding with a DC machine which is better and easier to weld with. - to the frame work and + to the rod or is it better to run it reverse so its + to the frame work and - to the rod. I was looking at a welding rod box the other day and saw it said something about reverse on 7018 rod. Right now my welder is set up - to the frame/ground and + to the rod. What say you guys??
Thanks
shawnspeed3
03-30-2007 09:26:21
 Re: Welding question in reply to old, 03-28-2007 11:36:01
If you think the Hf helps starting, you should also try a remote amperage setting(foot pedal as in TIG welding)I use my tig machine to stick weld some of my farm repairs leaving the remote contact and Hf on....easy starts and lots of control...Shawn
DNWELDMAN
03-30-2007 01:27:05
When welding with a positive ground(DC-) it is generally easier to go uphill and overhead(out of position). I"m an industrial welder and have passed my certifications both ways. And don"t run AC at all, stick with DC. 3/16" and 1/4" will run fine. On excavator buckets I run 3/16" all day long and then some with no problem. Also when setting up your welder This rule of thumb will get you close(each person is different). Take the decimal equivalent of the rod size and that will be close to your heat. 1/8"=.125= 125 amps, 3/32=.9375= 93 amps, and so on. Have fun with your tinkerin".Doug
135 Fan
03-30-2007 22:06:04
 Re: Welding question in reply to DNWELDMAN, 03-30-2007 01:27:05
Your heat settings would be close for 7018 but it is designed for DC reverse polarity or AC only. You can never go by what the machine says when setting current. Every machine will be different. Most welders will take a piece of scrap to set their heat unless they are familar with the machine. On a critical weld with a strict procedure qualification they will actually hook up an auxillary amp and volt meter to test the current to make sure it falls within specs. Machines can be calibrated as well. Preheat and interpass temperatures usually have to maintained as well. Too hot can be harmful to weld quality as well as too cold. When burning 1/4 inch and to less extent 3/16 arc blow on DC can be a big problem. AC is sometimes the only remedy other than using smaller rods. Vertical should be done uphand most of the time and you need to weave fairly wide to burn 3/16 rods. Most codes don't want the weave to be more than 2 1/2 times the diameter of the rod. Most welders will weave a little wider but not much. DC machines are way better but also cost a lot more. Dave
135 Fan
03-28-2007 20:03:53
7018 run best on DC. They are designed to run on DCRP (reverse polarity) electrode positive. It is called Reverse polarity because in welding current normally flows from negative to positive which would be straight polarity. The ONLY time 7018 will work better on an AC machine is if you are using large 3/16 or 1/4 inch electrodes at high amps and you are getting arc blow from magnetic fields in the welding current and steel. Industrial AC machines used to be made for this reason and no they didn't use a high frequency. High frquency is used for TIG welding and not stick. If high frequency helps on AC, it will still not be as good as DC. On a cheaper AC machine it is harder to weld with 7018 and that's why they make special AC 7018. They aren't as good as regular 7018. Your welder is set up right for 7018. Most of the time reverse polarity is used. Some rods like 7024 can run on both polarities and AC. They actually weld the nicest on straight polarity but if burning large rods AC could be better because of arc blow. Arc blow is common when welding around a lot of corners like I-beams ect. Dave
Rockyhawaii
03-28-2007 16:03:28
I've owned a AC/DC machine for 25 years or more and never tried the DC until I read this forum. I tried it and I'm hooked. My welds look better than ever.
joe from wi
03-28-2007 14:14:02
hi, DC reverse polarity for 7018 on mild steel. get your heat(amperage) electrode size, angle and travel speed correct, and the slag will peel itself off of your weld bead with minimum chipping or weld splatter. most mild steel applications work smoother, and more stable with dcrp . and ALOT less splatter! hope this helps...joe.
Stan in Oly, WA
03-28-2007 12:08:28
Hi old,
DC- not only changes the ratio of heat to the rod/heat to the work, but also works better with some rods than with others. For example, about the only use of 6012 rod that I've found is welding poor fit up running DC-. But it's excellent at that.
Stan
mj
03-28-2007 11:53:25
DCRP (direct current reverse polarity) means that the electrode is + or 'positive'. DCSP (direct current straight polarity) is when the electrode is - or 'negative'.
RossIL
03-28-2007 11:50:53
I'd say it depends entirely on what you're welding. DC+ gives the most penetration on mild steel. If you're welding thinner metal go with DC-. I don't know about running 7018 on DC- but I know I've got to fight to get it started on AC. If I crank the welder up to 135 with 1/8 inch rod and tap hard I can start it okay. I really want an Lincoln IdealArc that has AC, DC+, DC- all in one where you just flip a switch to change the setting (not the leads) and a rheostat to change the amperage.
Ross
mj
03-28-2007 11:57:53
 Re: Welding question in reply to RossIL, 03-28-2007 11:50:53
Or, just add a 'High Frequency Arc Stabilizer' to your AC machine; makes a buzz box start and run lo-hi and such easier than DC. :-)
RossIL
03-28-2007 13:44:18
 Re: Welding question in reply to mj, 03-28-2007 11:57:53
Really? I've never used one. My father has one but he's only ever used it to TIG weld aluminum. I never thought about using it for regular steel.
mj
03-28-2007 15:30:48
 Re: Welding question in reply to RossIL, 03-28-2007 13:44:18
Yeah, I run the hi-freq over my AC all the time. A world of difference!
