Tool Talk Discussion Forum
Impact Wrench
Wrenchead
03-27-2007 07:12:53
Well, looks like I'm going to have to break down and buy a 1" impact wrench. Need it to occasionally break track bolts on bulldozer or remove 2.5" nut holding steering clutch pack together etc.
Looking in Northern tools. Big price difference between their brand and Ingersol Rand. What should I really be looking at...torque, speed, BPM etc. Again, real occassional use.
My compressor will easily run anyone listed, so that's not a concern.
Your input is appreciated.
Cliff Neubauer
03-28-2007 09:19:43
 Re: Impact Wrench in reply to Wrenchead, 03-27-2007 07:12:53
Look at the torque ratings, I have an IR 2141 3/4" gun that's rated at 1,200 ft/lbs, to get a higher torque than that even in a 1" drive gun was going to double the price and the cheaper 1" guns were about the same torque. Since we already have the 3/4" drive socket set I chose to buy the best 3/4" gun I could rather than buy a cheaper 1" gun and a set of sockets to use with it. I'm running a 1/2" hose to my 3/4" gun at 175 psi and wouldn't want anything less on it.
Don L C
03-27-2007 14:56:47
For occasional use I would go with the Northern brand.....
Davis In SC
03-27-2007 13:58:30
Have you considered a manual Swench Impact wrench? No air needed, the 1 inch model goes up to 2,000 ft/lbs.. Too expensive to buy a new one, but nice used ones sell on Ebay for a few hundred dollars...
souNdguy
03-27-2007 11:56:03
We have the northern tools one at work.. it's a real beast. I've onle seen a few nuts it wouldn't remove or twist off.
I see harbor freight has them now too.. I'm almost tempted... I knida like the idea of an airgun that handles like a chainsaw...
Soundguy
TimS in Mo
03-27-2007 11:46:03
I have an ir brand 1/2 impact wrench, what size air hose should I be using with it?
Roy Suomi
03-27-2007 17:14:49
 Re: Impact Wrench in reply to TimS in Mo, 03-27-2007 11:46:03
Minimum 3/8" hose....
Mike M
03-27-2007 10:03:27
You also need to run the very large dia. air hose to them for enough volume.
big jt
03-27-2007 09:30:21
For occasional use Torque is the number you are looking for.
Years back I bought a 3/4 IR (from Harbor Freight) that comes close to the lighter 1" stuff. works good for what I use it for. Mostly "budd" rims. Lot easier to handle than the 1" two handers.
jt
glennster
03-27-2007 09:29:57
i'd go with the ingersol. i have a 3/4 drive northern not worth a dip. my 1/2 drive snap on walks all over it. i use the northern one for a door stop.
