Tool Talk Discussion Forum
C-Clips J-Clips
Slowpoke
03-25-2007 15:25:28
C-Clips & J-Clips are used a few places on tractor sheetmetal. The J-Clip has only half the top section compared to a C-Clip. How do you determine which one to use?
Thanks
paul
03-26-2007 23:10:52
 Re: C-Clips J-Clips in reply to Slowpoke, 03-25-2007 15:25:28
So..... ...
These are the little retaining type of sheet metal deals folded over that have a barb or 2 to catch the threads of a bolt & keep bits of sheet metal in place? They slip over the edge of the sheet metal with a hole in it?
--->Paul
Glen in TX
03-26-2007 12:55:38
Take a look at Au-ve-co Products. They make those and call them U & J nuts. There are spring type U nuts, U type special nuts, J type cage nuts, Extruded U nuts (foldover nuts) in inch or metric sizes. Also flat nuts that some call pal nuts. Others you might check with are millsupply.com or mcmaster.com
neblinc
03-26-2007 10:57:56
Same guy using 3 names. He was just calling himself dummy, that is allowed ;)
Randy
Slowpoke
03-26-2007 11:09:31
 Re: C-Clips J-Clips in reply to neblinc, 03-26-2007 10:57:56
Thanks Randy
Does anyone have an answer to the U-Clip and J-Clip question?
How can you
03-25-2007 23:42:08
compare them when they are totaly different.
It's supposed to be U-clip, Dummy, not C-Clip. So I will rephrase the question: When do you use a U-clip and when do you use a J-clip? Hope this helps.
Slowpoke
Eddie in MI
03-26-2007 03:46:21
 Re: C-Clips J-Clips in reply to How can you, 03-25-2007 23:42:08
Geez... you need to calm down. All he did was ask a question. If he knew the answer already, he wouldn't be asking now, would he????
Calling people "dummy" is really just pathetic and inappropriate. :(
Slowpoke
03-26-2007 10:42:11
 Re: C-Clips J-Clips in reply to Eddie in MI, 03-26-2007 03:46:21
Sometimes we fail to see things untill it's too late. The question was proof read and the error was still not seen. And sometimes we also fail to read "every last word" of a post. Especially the one pointing out the error.
Hope this helps.
Easy1
03-26-2007 08:20:06
Cut this guy off! No more coffee!!! LOL
Well, I never
03-26-2007 10:45:58
 Re: C-Clips J-Clips in reply to Easy1, 03-26-2007 08:20:06
drink anything but decaf....
